It is currently Thu Aug 07, 2025 6:00 pm
PostPosted: Thu Aug 06, 2009 6:19 pm
Last Name: Sollod
On my second build (I've done 4 so far and starting #5) I used cocobolo for the rosette. When I put on the Z-poxy it bled. gaah I managed to overcome that (to some degree). So, I know cocobolo bleeds. I've used rosewood and lacewood (which turned out very nice) and I got no bleeding. I'm getting ready to use claro walnut and I expect it not to bleed. What about african blackwood? ... ebony? ...any others tend to bleed?
www.swiftcreekguitars.com
PostPosted: Thu Aug 06, 2009 6:42 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I am certainly no expert, but I bent Madagascar RW bindings and they "bled"- left some residue on my steel bending slats.
Glenn
PostPosted: Thu Aug 06, 2009 8:22 pm
Last Name: Cox
I would expect it out of every single flavor of Rosewood on the planet...
I might be careful with about any of the oily tropical woods...
Then you got the regular problem with anything Dark -- dust staining stuff... Ebony is famous for its black dust getting on *EVERYTHING*
Good luck
PostPosted: Fri Aug 07, 2009 3:02 am
Last Name: Beaver
City: Lake Forest
The best bet is test a piece of the wood with whatever finish you are using. If it is going to bleed into a lighter wood then carefully coat the bleeding wood with the epoxy. Masking tape may help on things like maple bindings or the sound board. Then remove the tape, let the epoxy dry, sand lightly and reapply the epoxy over the whole piece, bindings and all. You have it sealed so there should be no problem. (epoxing the top is optional. I only do it with cedar and flamed redwood.)
Also be careful wiping the wood with naptha or alcohol. That will cause bleeding. (don't use naptha if you are planning a water based finish, unless you use it before you seal with epoxy. I would still just use alcohol)
Joe
Joe Beaver
Maker of Sawdust
PostPosted: Fri Aug 07, 2009 6:58 am
First name: Erik
Last Name: Hauri
State: Maryland
Quote:
Woods that tend to bleed?
Bloodwood
duh
seriously
The member formerly known as erikbojerik....
PostPosted: Fri Aug 07, 2009 7:03 am
PADAUK... Bleeds like crazy and the dust gets everywhere...
Guitar Building = Continuous Improvement Process
PostPosted: Fri Aug 07, 2009 10:10 am
Last Name: Garrish
Walnut and ebony don't bleed, but ebony dust does get everywhere. Generally, it's easiest to just scrape lightly with a razor after you're done messing with the ebony to take the dust off of lighter woods. It doesn't penetrate very deep at all.
Bob Garrish
PostPosted: Fri Aug 07, 2009 12:47 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
For bleeding woods I spray a light coat of blond shellac on them.
I spray it on because wiping would cause bleeding.
You can use spray can shellac but beware !
it's mostly thinner and to thick a coat will draw the oils out of the oily woods and bleed onto tops & such .
After it's dry you can apply any finish over it without bleeding.
Mike Collins
PostPosted: Fri Aug 07, 2009 12:58 pm
I agree
Shellac sealing keeps the oils from inpregnating lighter woods. still will require some scraping back aft the fill is complete
PostPosted: Fri Aug 07, 2009 1:52 pm
I don't know which woods bleed, but I know which parts, my FINGERS!
PostPosted: Fri Aug 07, 2009 2:38 pm
Last Name: Shaw
City: Philadelphia
Padauk can bleed. Washcoat of dewaxed shellac can prevent this.
PostPosted: Mon Aug 10, 2009 9:47 am
First name: Corky
Last Name: Long
City: Mount Kisco
Black Walnut is an interesting one. While I haven't had trouble with bleeding per se, it will stain your hands (and other things too, I'm thinking) something fierce if you get the sawdust on them.
Users browsing this forum: J De Rocher and 38 guests
