It is currently Fri Aug 08, 2025 2:07 am
 Post subject: Spoke Shaves
PostPosted: Fri Aug 14, 2009 8:51 am
Last Name: Charnock
Country: UK
Hi
I am new to building and have yet to start my first project. I am currently tooling up, I was wondering if a Spoke Shave is one of the tool of choice for shaping the neck? if so are they curved or flat ?
 Post subject: Re: Spoke Shaves
PostPosted: Fri Aug 14, 2009 9:52 am
Flat.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Aug 14, 2009 10:57 am
Welcome to the OLF, John.
I use a flat Stanley 151 that's a great tool, but I would like to try one with a crescent-shaped iron and sole.
PostPosted: Fri Aug 14, 2009 12:31 pm
I second the "flat" comment.
I have spent many fruitless hours tuning and trying to get a curved sole spokeshave to cut cleanly.
PostPosted: Fri Aug 14, 2009 12:33 pm
First name: Tom
Last Name: West
State: Nova Scotia
Flat spoke one of my most used tools for neck carving...!
PostPosted: Fri Aug 14, 2009 1:23 pm
First name: mike
Last Name: mcgrail
State: ky
I have 5 different spokeshaves, but the one I like best is a light-duty round bottom kunz(cheap german brand) that goes for 13.99 at the highland hardware now- it was about 6 bucks when i bought it(yes I am old). It is sort of a pain to adjust that first time but I like it better than all the others. It is just the right size and the round sole lets you get up close to the curve. I would not leave home without it. Try it.
PostPosted: Fri Aug 14, 2009 6:18 pm
Last Name: Sollod
I made the mistake of buying an inexpensive (cheap) spoke shave and I hated it. gaah [uncle] I took it back to the store and ended up using my LN Model Makers Plane. It worked great! [:Y:] I'll likely continue to use it and not bother with buying a spoke shave. At least for a while (or longer...).
www.swiftcreekguitars.com
PostPosted: Fri Aug 14, 2009 7:19 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
For a great selection of low-angle shaves- some of which can work in pretty tight turns, google "Dave's Shaves"
PostPosted: Fri Aug 14, 2009 7:20 pm
I have the Veritas low angle as well as the flat spokeshave with the Bubinga handles. They both work great, but my favorite is the one I built out of Lignum using the veritas spokeshave hardware kit. A real pleasure to use. I do agree with Todd on the rasp before shave though if you're on a budget.
PostPosted: Fri Aug 14, 2009 7:30 pm
Someone here pointed me to this small drawknife from Japan Woodworker. The cost is $47.95 and it works great.
http://www.japanwoodworker.com/product. ... t_id=13217
They also have a curved version ($51.20)
PostPosted: Fri Aug 14, 2009 8:03 pm
First name: Tom
Last Name: West
State: Nova Scotia
Around here spoke shaves tend to show up on a regular basis at flea markets etc and at a low price.I've acquired 3 that way and I think the highest price was 8 bucks.
PostPosted: Sat Aug 15, 2009 10:29 am
I used a cheapy, new stanley curved bottom metal shave for my first neck (just finished) and I had to put HOURS of time tuning it up so it would even cut.
Then I bought a kit from Lee Valley (a Veritas spoke shave kit) and built my own w/ a flat sole and it is amazing - SOOOOO smooth to use and can take shavings as thin as a smoothing plane (~.001-.002") if you do it right. It takes time, but I would highly recommend spending the $40 for a nice Veritas kit
PostPosted: Sat Aug 15, 2009 10:41 am
If the Veritas kit looks promising, you might want to check out ALF's pages on building one. Lots of good information there. http://www.cornishworkshop.co.uk/spokeshavekit.html
PostPosted: Sat Aug 15, 2009 11:48 am
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Darrel Friesen wrote:
.....but my favorite is the one I built out of Lignum using the veritas spokeshave hardware kit. A real pleasure to use.
I have a few spokeshaves and my favorite by far is an applewood 11" Bagshaw & Field shave with a 2" blade. I got mine on ebay for under $15. I wouldn't bother with metal shaves - you'll love the feel of the wood shave in your hand. If you buy one, I'd recommend not spending more than $20-25 on one in good shape and get one with the brass wear strip and with durable wood (any fruitwood, boxwood, rosewood, ect). I just checked ebay - out of the 8 or so, none look good or they want big $$.
If you like making tools, the Veritas kit that Darrel talks about may be your best bet. I'm going to get one to build - they look nice.
Good luck-
John Lewis
PostPosted: Sat Aug 15, 2009 12:06 pm
What John said!
I've got a bunch. The metal ones are crap. The most effective & satisfying to use by far is one not unlike Johns, but curved bottom (maybe 12"R). Tangs only. Gotta be 100 yrs old. Used it on Windsor chairs, guitar necks, etc. A good one is a joy....a bad one makes you want to rip your own head off!
Milton, ON
PostPosted: Sat Aug 15, 2009 1:01 pm
I'm going to try to find one of those nice wood spoke shaves. I have several of the metal ones and don't use them.
PostPosted: Sat Aug 15, 2009 5:16 pm
Last Name: Shaw
City: Philadelphia
Both! I have two old stanleys. One flat and one curved. The curved can be used on the heal of the neck or the side of the headstock if yours are not staright like a martin.
PostPosted: Sun Aug 16, 2009 3:19 pm
Todd Stock wrote:
Let's differentiate between the crap metal ones (the Stanley/Record/Kunz 151 and 151R shaves) and the LN and LV Boggs and Preston shaves, which work just fine once set up. Got a pile of old wooden shaves too, and have made a few back in the day. For curved work around the heel, I like them, assuming I am not in a hurry and don't just drawknife/rasp things to shape. For the flat runs on the shaft, the longer, wider sole and larger bearing surface of a metal plane is pretty handy.
Todd,
Let's further differentiate between the new Stanley 151s and the older ones whose irons fit properly and adjust easily. Much like the difference between old and new block planes.
PostPosted: Sun Aug 16, 2009 5:00 pm
Last Name: Shaw
City: Philadelphia
Yes i have older stanleys and they are fine. Never had a problem with them. The newer ones i wouldn't now about since most of my planes and chisels are of vintage age.
PostPosted: Sun Aug 16, 2009 5:44 pm
I have a selection of vintage shaves. The LN curved is my go to. The curve is so subtle but just enough to put in the "arc" with your wrists and subtle enough that it also works well as a "flat." In the wooden style, I actually like the "gunsmiths' scraper" style tool. They are comfortable and effective.
PostPosted: Sun Aug 16, 2009 7:19 pm
Mike,
Nice to see you posting! Long time no see! How's things going for you?
PostPosted: Mon Aug 17, 2009 8:57 am
It is great to be back. You are such a great bunch of folks, here. I am trying to set up to supplement Social Security with some guitars. My Les Paul "replicas"(mine are legal; true replication but no trademark infringement on the headstock) are a main focus, but I really wanted to re-invest myself into acoustics. I get to use my beloved handtools so much more and I am really more of an acoustic player.
I am hoping to improve my acoustic build skills toward perhaps the possibility of selling some guitars regionally. I am relying upon John Hall to help me get back in. He is bending some RC Zoot Imbuia for a Martin Slope Dread(I have his mold) and I am cheating with his help rounding up a Martin 12 fret 12 string neck and block. I am finally on the road to finishing my idle walnut/sitka OM- Making top braces reawakened that glow you get while attending to the handwork detail that is so much a part of the lure of the acoustic build.
I am ashamed of how my radius dishes and radiused guitar shapes from Tracy have been sitting so idle and my go-bar deck going nowhere. I am well tooled up for acoustics and it was foolish of me to abandon the art.
My mental disabilities are leveled out- I have reminders and checklists all over the little house. I just have to remember to read and use them [headinwall] . Thanks for the welcome and a warm hello to all from me. Mike
