It is currently Fri Aug 08, 2025 12:33 am
PostPosted: Sat Aug 15, 2009 12:32 pm
Country: Romania
I would flood them now. You can also try to position the side on the plank in way that does not put the knot in any of the 3 tighter bend areas - I hope this makes sense.
Build log
Last edited by Alexandru Marian on Sat Aug 15, 2009 12:33 pm, edited 1 time in total.
Hi Filippo
I'm a complete novice so wait for more experienced builders to chime in.
However, I've just made up a body in BRW which was in a pretty bad state with knots and cracks etc. I flooded the knots and cracks with CA and also filled with Epoxy and wood dust. I did this before and after thicknessing. I managed to bend the sides pretty good with no problems in the weakened areas.
I have also read on here that due to it's proneness to cracking, a lot of builders are doing the Pore filling with CA. This seems like a good idea especially with the knot problem etc. It can only help.
Anyways, like I say - best to wait for someone with some real experience to chime in.
Good luck with the wood, it looks real nice [:Y:]
Mat
