It is currently Fri Aug 08, 2025 3:43 am
 Post subject: Which drum sander?
PostPosted: Fri Aug 14, 2009 4:34 pm
I am finally going to break down, & buy a drum sander. I can get the new Delta (31-260X), or the Jet (16-32) for roughly the same price. My local tool dealer highly recommends the Delta, but I seem to recall reading somewhere (or, I may have heard it) that for making guitars, the Jet is a better choice. Space is an issue, & I don't feel like making one. Any guidance would be greatly appreciated......don
 Post subject: Re: Which drum sander?
PostPosted: Fri Aug 14, 2009 5:33 pm
I went through the same process and finally bought a Jet 10-20 4 months ago. I also have limited space and so far I'm really glad I went ahead and got it. It's a huge improvement over the Wagner safety planer, a hand plane, and a ROS. A larger sander is probably better if you have the room, of course.
PostPosted: Fri Aug 14, 2009 6:09 pm
Last Name: Sollod
I'll second the 10-20. I expect Hesh to chime in too. He is a big fan of the 10-20. Not a lot of space needed since it sits on your bench. I love it. [:Y:]
www.swiftcreekguitars.com
PostPosted: Fri Aug 14, 2009 6:21 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I bought a used 18x36 Delta ( older model ) and have no issues with it and at $500 it was really a good deal. Get some 40 or 60 grit paper for what ever you buy if you are going to use it to remove a lot of stock, 80 grit will load up real bad, I ruined my 1st 80 grit belt sanding my 1st set of cocobolo, I did the second set of cocobolo and P@ul's bubinga on a 60 grit belt and it is still going strong. Leave a little stock and finish with 120. The nice thing about 18" is a joined top or back can be ran straight through.
As for space it only uses extra space when sanding and can be pushed against the wall or in a corner for storage.
Fred
Fred Tellier
PostPosted: Fri Aug 14, 2009 7:34 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got a 10-20, and like other I really like it, and have limited space.
PostPosted: Fri Aug 14, 2009 7:43 pm
I've been using a used Performax 22-44 (Zootman's old unit) for a year now and don't know how I ever lived without one. It's capable of handling anything that instrument making could ever throw at it, including fully joined plates in one pass over the full width. It's on a wheeled cart and can be moved away when not in use.
My advice...get the widest sander you have room for and can afford.
PostPosted: Sat Aug 15, 2009 10:43 am
I just recently bought a used Performax 16 32 Plus. So are I am really happy with it. I had the 10 20 and it seemed to do just fine also. I got the larger one because I need to build some storage units and the width will be way beyond the 10 20 plus.
Chuck
PostPosted: Sat Aug 15, 2009 5:26 pm
Last Name: Shaw
City: Philadelphia
I have a performax 10/20. Its is identical to the jet and made by them. Its great little machine. Heavy little sucker though.
PostPosted: Sun Aug 16, 2009 10:26 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I have just hooked up my 26" Steel City monster - with dual drums it can do 80 and 120 in a single pass.
I picked it up used for a fraction of the new price :)
Thicknessed my first back yesterday - works like a charm!
PostPosted: Sun Aug 16, 2009 12:12 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Another vote for the Jet 10/20 (my version is the 10/20 Plus - not sure what that signifies)
The only caveat is that changing paper's a little tricky. But once you get the hang of it it's not too tough. Good performance, good price.
PostPosted: Mon Aug 17, 2009 7:51 am
I went with the Delta 18/36 and glad i did.It does anything asked of it and i like the fact that it was made in the USA.It does full size dreadnaught top and back plates with great precision.
