It is currently Fri Aug 08, 2025 9:38 am
 Post subject: Binding videos
PostPosted: Mon Sep 07, 2009 7:24 am
Here are some You tube videos for binding a guitar. It may help clear up some things. Hope you like them
http://www.youtube.com/watch?v=Lan2pKWE1Do
http://www.youtube.com/watch?v=9cwJiOVzE_E
http://www.youtube.com/watch?v=-364fAT89b8
 Post subject: Re: Binding videos
PostPosted: Mon Sep 07, 2009 7:52 am
Fantastic, John!!! Thanks for sharing.
I sure could have used this 7 years ago!!!
PostPosted: Mon Sep 07, 2009 7:54 am
Nicely done John. My only suggestion would be to recommend hearing protection while doing this procedure. I like the copper tape idea for fine tuning the cuts.
Terry
PostPosted: Mon Sep 07, 2009 9:50 am
Great job John! Like the tip about the copper tape. Any reason why you did not use tape on the side when routing for top binding?
Chuck
PostPosted: Mon Sep 07, 2009 9:52 am
I forgot , I got into the video and well i knew someone would let me know
I have a bending video to come out soon to
thanks
PostPosted: Mon Sep 07, 2009 10:00 am
First name: Jim
Last Name: Hansen
Hey John,
Thanks for the links!
I have a question or two.
I noticed you don't secure the work to the table and instead kinda move it around with one hand while you are working with the other. I'm not sure I could get away with this safely (i'm a bit of a n00b around fast spinney metal things). Isn't one of the benefits of that particular style of machine that you can secure the work to the bench top?
Also, I noticed you removed the masking tape after the first pass, and then made a cleanup pass. Is this done for a reason? Isn't there still a risk of a spinning bearing damaging the side?
Jim Hansen
PostPosted: Mon Sep 07, 2009 10:25 am
The tape is removed for just that ,to make the clean up cuts. There is no reason to fasten the base down. There is enough mass to keep anything from flying . I like the freedom to move things around for visual and space constraints.
PostPosted: Mon Sep 07, 2009 11:11 am
I really like that binding machine better than mine....Hmmm, some day!
Oh yeah, sorry........ a respirator would be a good idea too [:Y:]
Gwaltney Guitars
PostPosted: Mon Sep 07, 2009 12:01 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Great video John. I also move the base some not a problem. My table is very solid and flat and I use a tall machinist square and do the neck and tail block area's. Also use them to square the bouts, maybe not just as critically as the front and rear though but very close. Don't mean to hijack just another method of getting square body and good channels. I have this model and your old style also and both work great. I remember about 6 years ago used the old Chicago trimmers and like the new PC better. More accurate and stable
PostPosted: Mon Sep 07, 2009 1:42 pm
First name: Hugh
City: Lake Oswego
State: oregon
Would that system work with a stationary router set-up, since you can move the guitar around?
PostPosted: Mon Sep 07, 2009 2:05 pm
First name: Florian
Last Name: THOMAS
City: Bernieulles
Country: France
the only thing I wasn't confident with on this kind of jig was the depth of the routing that would vary quite alot if the bottom of the router would stay flat... but your angled nylon plate is the solution... a really really good idea.
thanks for the tip !
wonderful job
PostPosted: Mon Sep 07, 2009 3:47 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Nice job John, I will echo JJ's comments except in my case 4 years. I have liked the video tutorials presented by list members even though I have pretty much already figured things out the hard way. John, Chris and Robbie will get a big thank you in person when I get the chance as I have picked up lots of things from all the videos that have helped my techniques greatly.
I hope you all keep the videos coming in the future, there are lots of topics left to cover.
Thanks guys
Fred
Fred Tellier
PostPosted: Mon Sep 07, 2009 6:56 pm
The next planned video is neck setting
PostPosted: Mon Sep 07, 2009 7:08 pm
[:Y:] [:Y:] [:Y:] You have anymore planned?
PostPosted: Mon Sep 07, 2009 7:20 pm
I want to do most basic processes , and i will be doing some inlay . Keep an eye out for blues creek guitars on You Tube. I hope to do more
PostPosted: Mon Sep 07, 2009 7:28 pm
I subscribed to your channel so I won't miss them.
PostPosted: Mon Sep 07, 2009 8:09 pm
Online
John, thank you!
PostPosted: Mon Sep 07, 2009 8:40 pm
John- I thanked you for this in the bending post. But I wanted to make sure I got it said here too. Mike T.
PostPosted: Tue Sep 08, 2009 2:44 pm
Online
I subscribed, too :D
John, will you help clarify something for me? You covered it in the video, but I need a little extra support. Am I correct in thinking that the idea is to get the sides perpendicular to the table with the holding fixture? It's not to get the top or back parallel, it's to get the sides perpendicular?
PostPosted: Wed Sep 09, 2009 6:33 am
John--I have my all but complete W-F jig, sitting trimmerless. How did you mount the 7310 to the business end of the arm? I have a 7310 new in the box, waiting for a proven method. I ask, because it does not appear that the attachment is on a horizontal platform at the bottom of an "L" shaped end piece.
My plan had been to use a piece of lucite as the horizontal platform with a counterbore for a flanged Nylon sleeve bearing(1" ID) and the trimmer screwed to the horizontal on top of the counterbore and centered. Then the sleeve portion of the nylon bearing extending about 1/4" from the bottom would be the "donut"(wall thickness is 1/8th"). Any suggestion-John or anyone? Thanks, Mike T.
PostPosted: Wed Sep 09, 2009 6:51 am
I use the base screw to mount the router so I have max capability of the router
PostPosted: Wed Sep 09, 2009 2:34 pm
I use this jig from Blues Creek Guitars at Red Rocks Community College. Great product from a great company. Thanks John!
Users browsing this forum: No registered users and 45 guests
