It is currently Fri Aug 08, 2025 1:18 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Sep 30, 2009 1:26 am
Last Name: Shaw
City: Philadelphia
450lbs! Oh you said on your bench. :)
PostPosted: Wed Sep 30, 2009 9:14 am
16"top is on the little bench...
PostPosted: Wed Sep 30, 2009 9:41 am
0n the big bench.... A 16" and a 17", necks rough set, ready for inlays, and fingerboards
PostPosted: Thu Oct 01, 2009 9:15 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I have several things on my bench:
Currently have 3 guitars in progress: L-00 african Mahogany B&S, Adi top; Jumbo PS african mahogany lutz top; OM EI RW B&S lutz top.
Picture of L-00 and Mad RW bindings for L-00 and Jumbo PS, and Sycamore for OM.
While not on my bench, I just received this Grizzly Bandsaw and set it up this week.
Glenn
PostPosted: Thu Oct 01, 2009 11:48 am
topless! I've 2 still under construction.
Thanks for looking.
Jeff
PostPosted: Thu Oct 01, 2009 12:09 pm
Hey Jeff, are you drilling holes in your back braces?
Got another pic from a different angle that would show what's going on there?
PostPosted: Thu Oct 01, 2009 3:13 pm
Last Name: Hodge
Jeffrey those are going to be beautiful. Is that Monkey Pod I see there?
Bill Hodge
PostPosted: Thu Oct 01, 2009 8:02 pm
Hi Bill,
No, those are MBW.
here's a picture of the back.
Jeff
PostPosted: Fri Oct 02, 2009 6:23 am
Last Name: Hodge
Stunning! Thanks Jeff, looking at those raises my appetite. Guess I better go grab a bite to eat. :D I really enjoy looking at the Monkey Pod guitars you've produced and thought you'd found a darker batch. I'll bet these ring like gongs.
Bill Hodge
PostPosted: Fri Oct 02, 2009 9:21 pm
Interesting stuff going on their Jeff. I would expect nothing less out of you! [:Y:]
PostPosted: Fri Oct 02, 2009 9:33 pm
Here is a classical top on my personal bench. Braces were shaped with a Stephen Boone mini wooden hand plane.
PostPosted: Sat Oct 03, 2009 11:32 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I have two on the go, this is the Classical, Englemann & Ovankol, using the 6-fan Ramirez bracing pattern:
Here is a shot of the Ovankol back - I like how the black streaks offset the ebony binding:
And here is my SS, Lutz (thanks Shane, beautiful wood) and EIR - inspired by Shane's Greven I had the pleasure of seeing when I was in Terrace:
PostPosted: Sat Oct 03, 2009 8:49 pm
Posted this guy a couple weeks ago. Finished the tweaks and final polish, sent him off with his new owner today.
PostPosted: Mon Oct 05, 2009 11:34 am
I was browsing in a hardware store, and saw these huge quick connects for pneumatic tools, like air hammers, and thought it might work as a swivel mount for my solera. Don't know if it will work, ultimately, but thought it was worth a try. Here are some pics of what I have so far.
Male and female parts.
The mated pair.
Mounting.
It is fairly stable, but not as firm as I would like, and it turns a little easily. I replaced the soft washer in it with some hard rubber washers, and it is more stable, but I think I'm going to drill some registration holes in it an put a pin in there to keep it from turning. That may also add a small amount of stability. Then I can turn it with the pin out and reinsert for locking. Only time will tell if it will be acceptable.
PostPosted: Mon Oct 05, 2009 3:37 pm
First name: Nelson
Last Name: Palen
Interesting idea, Waddy!
PostPosted: Tue Oct 06, 2009 9:01 am
Last Name: Hodge
Robbie O, Robbie Mc, and Pat, those are sweeeeeeeet!!! [:Y:]
Waddy, you're a genius!!! [clap]
Bill Hodge
PostPosted: Tue Oct 06, 2009 9:51 am
Thanks, guys. Don't even know if it will actually work. I'm pretty sure it will for some things, but if you have to put much pressure anywhere, it may be too unstable. We'll see, I guess. It does rock a little. Maybe it won't if I put a pin in it. I just need to put it in the right place.
Users browsing this forum: A.Hix, Bing [Bot] and 38 guests
