It is currently Mon Sep 15, 2025 2:39 pm
PostPosted: Sat Oct 24, 2009 10:31 pm
First name: shad
Last Name: peters
i have done my last 3 guitars with spray can lacquer which works fine i suppose, but i would really to get a good spray setup i am wanting to start doing some tinted finishes and just devolop my skills in general in a way that i dont think i can do without having a descent setup. but the other thing is that i don't have ton of money... so are there any good guns out there for a descent price? i know stewmac has one but i have never heard anything about. i was also wondering what type of compressor i would need, or would be best. i was thinking i had heard before that with a spray gun cfm matters more than max psi and all that. any suggestions would be appreciated.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Sat Oct 24, 2009 10:46 pm
Last Name: Shaw
City: Philadelphia
I use an siphon feed spray gun that I bought at Lowes. It works fine with standard lacquers and water based. I only have a 20 gallon 1 and 1/4 HP compressor and this setup is sufficient for this gun. Beware of the HVLP spray gun since these need a much larger compressor then a standard siphon type. You could also go with a HVLP turbine setup which is a gun and a tank less air turbine but then you can't use it to run other tools like a standard compressor...Mike
PostPosted: Sun Oct 25, 2009 12:10 am
http://www.spraygundepot.com/?gclid=CO7 ... sgodaCF2rw
Just about anything your heart desires....as far a paint equipment goes! [:Y:]
Do a search for inexpensive spray paint guns and you will find some little hvlp jamb or touchup guns for as low as $29.00
cron
