It is currently Sat Aug 09, 2025 3:26 am
PostPosted: Sun Oct 25, 2009 5:15 pm
First name: Wendy
Last Name: W
State: Arizona
Can anyone tell me if it is possible to change a waist bend after the bend has been set? I thought I had it cranked all the way down, but now I can see through the slot in the bender that there is still a small gap. gaah Can I re-wet the waist and heat it back up in the bender and crank it the rest of the way down? Has anyone ever done this?
PostPosted: Sun Oct 25, 2009 5:20 pm
City: Lawrence
Zip/Postal Code: 66047
Shouldn't be a problem. I don't think you could reverse the bend but you should be okay putting more bend in it
PostPosted: Sun Oct 25, 2009 5:27 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Yep, should be easy enough. I've bent a pair of sides both the same (doh!) before, and then flattenend one out and rebent it the correct way completely without any issues.
Good luck,
Dave F.
Cambrian Guitars
PostPosted: Sun Oct 25, 2009 5:37 pm
City: Lawrence
Good luck,
Dave F.
Thats good to know Dave. Thanks
PostPosted: Sun Oct 25, 2009 5:46 pm
First name: Matthew
Last Name: Rust
City: Columbus
Zip/Postal Code: 47201
I just found this out today... I had a side that I started to bend on a hot pipe and decided not to use that set. So I flattened it back out for storage. Hopefully it will let me re-bend once the time comes to use it!
Don't confront me with my failures--I have not forgotten them.
PostPosted: Mon Oct 26, 2009 1:34 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Wendy,
I once bent a profiled side backwards. I was encouraged to flatten it with an iron and rebend.
It came out fine.
PostPosted: Mon Oct 26, 2009 3:37 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I often touch up waist bends by hand on the hot pipe, I just put a wet rag between the side and the iron it creates a lot of stream and it bends quick, for some reason the tight bends in a 000 waist sometimes open a little.
Putting the whole side back in the bender might scorch the wood, be careful.
Fred
Fred Tellier
PostPosted: Mon Oct 26, 2009 7:44 pm
First name: Wendy
Last Name: W
State: Arizona
I took it out of the bender after work today and the waist is usable the way it is, so I won't be rebending it. There is a bit of springback, more than I am used to, but it conforms to the mold so I'm leaving it alone. At least I know now for the future that sides can be rebent. Thanks, Wendy
Users browsing this forum: Bing [Bot] and 39 guests
