It is currently Sat Aug 09, 2025 8:07 am
PostPosted: Mon Oct 26, 2009 12:25 am
When you guys set the pressure for your spray guns, do you use the manufacturer's recommended setting? At 19 psi, my Iwata LP300's recommended setting is roughly half of what I've typically seen recommended across the forums.
PostPosted: Mon Oct 26, 2009 12:39 am
Yes, your gun is designed to operate at a specific pressure, adding any more to it offers no benefit.
PostPosted: Mon Oct 26, 2009 5:17 am
setting air pressure for spray guns is something I think there is more than a bit of confusion about..
I know with my Binks Mach 1SL the manual says to set it at 9-12psi..here's the rub, that's 9-12 psi as read on a regulator at the gun WHEN THE TRIGGER IS PULLED...to get that I typically have the pressure at my pressure pot set @ 33 or so...and the longer the hose I am using, the more pressure I need at the pot's air regulator...if I was using a smaller diameter hose, I would have to push the pressure even more...its all about the 'pass through' pressure, though of course once a system is set up and known one can refer to the pressure they have set via the regulator on the compressor or after the water/oil traps (which I refer to as the static pressure)
PostPosted: Mon Oct 26, 2009 6:30 am
I use a regulator on my gun and I follow the recommended pressure. Too much air can cause premature drying and all kinds of layout issues.
PostPosted: Mon Oct 26, 2009 7:51 am
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Make sure you set your pressure at the wall or compressor then use the regulator at your gun for very small adjustments.
Ken
http://www.casperguitar.com
PostPosted: Mon Oct 26, 2009 8:45 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've found that it's usually best to set the (flowing) pressure at or slightly below the maximum recommend for the gun, the adjust the air setting on the gun(usually near the end of the handle), as well as the fluid and fan controls (rear of the gun) to get a smooth finish. If you can't get a smooth finish like this you've probably got the wrong tip size or gun.
I believe most of the automotive finishes that recommend very specific tip and pressure combinations to the extreme of needing a digital regulator are waterbased......stuff, masquerading as automotive finishes.
PostPosted: Mon Oct 26, 2009 9:38 am
Something no one has mentioned is the viscosity of the finish itself .... varying this can affect how the pressure is set.
I think its Todd that mentions what you are after is the lowest setting that good atomization occurs .. I would agree with that. It gives the best application of the finish.
PostPosted: Mon Oct 26, 2009 2:33 pm
Oh, good, lol, it sounds like I've been doing it right. I shoot air and set the regulator at the gun. Should I be shooting air or finish?
We're moving into a house soon. It'll be good not to be rushed when I'm trying to dial everything in because of noise complaints.
Users browsing this forum: No registered users and 42 guests
