It is currently Sat Aug 09, 2025 6:14 am
PostPosted: Sat Oct 31, 2009 9:12 pm
First name: Big
Last Name: Jim
Every time i try and post a pic it says to large , im no computer genius how do i get it to post [headinwall]
PostPosted: Sat Oct 31, 2009 9:18 pm
You have to resize them. What operating system do you use?
PostPosted: Sat Oct 31, 2009 9:19 pm
If you are using a PC, with Windows XP, go to Windows Power Toys website and download the "Image Resizer" software. It's free, and then you can right click on your image file, and click resize. It will open a dialog box, and give options. I use the "Large" option, and that seems to work just fine for this site. It's very simple. Otherwise, you have to use a image editing program, and resize by exporting a new file size. Resizer is easier in my opinion.
PostPosted: Sat Oct 31, 2009 9:24 pm
First name: Big
Last Name: Jim
thanks will try the suggestion I have xp
PostPosted: Sat Oct 31, 2009 9:28 pm
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
You're going to need to download or use a photo editing program to resize your pictures. There's a long list of them here http://download.cnet.com/1770-20_4-0.ht ... xcdl.2.a.5
that are free, otherwise if you have photoshop or something similar you might be able to resize with that. Hope this helps.
PostPosted: Sat Oct 31, 2009 9:46 pm
Here is a link to the Windows Power Toys website. http://www.microsoft.com/windowsxp/Down ... rtoys.mspx
Look on the right side. Scroll down about 3/4 of the way down the page. Click on ImageResizer.exe, and it will download or install, depending on which browser you are using.
PostPosted: Sat Oct 31, 2009 9:50 pm
Last Name: Cox
I just use Paint to resize mine... Comes free with every Windows distribution ever...
I use the "Stretch/Skew" command -- only hint is to be sure you resize both directions the same or it comes out kinda hinky.... You will just have to keep shrinking it down until it is maybe 4" square on your monitor in Paint... then you will be OK on size...
It also saves in "High Compression" mode -- so it really makes images memory-thrifty...
The other thing about Paint is that it is very fast... so you can resize really quickly.
Tell us how it goes.
PostPosted: Sat Oct 31, 2009 10:37 pm
Last Name: Shaw
City: Philadelphia
yeah paints the way to go.
PostPosted: Sun Nov 01, 2009 7:45 am
First name: Big
Last Name: Jim
thanks everyone for advise , glad im better with wood than with computers duh
PostPosted: Sun Nov 01, 2009 9:07 am
Not to hijack, but I have tried this in paint several times, exactly as you describe. All it does is crop the picture, so that when resized I get the left top part of the picture. Very frustraing. What am I doing wrong?
PostPosted: Sun Nov 01, 2009 10:23 am
I love the resizer for windows xp application. I use it every day for work. You can resize as many images as you'd like all in a batch sitting. You can also customize the size in which you want to make your images. Also you can choose to make a copy of the image being resized or just resize the original (not recommended, you loose the original image).
Yup, best resizer for windows xp that I've found. And the price is definitely right (free :) )
PostPosted: Sun Nov 01, 2009 10:40 am
First name: shad
Last Name: peters
my computer save picture in an incorrect format to post online, (or at least on this website for some reason) i have to first upload mine onto flickr, and then right click to save image as once its uploaded, this puts the image in the correct format, and it also resizes the picture.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Sun Nov 01, 2009 10:45 am
First name: Big
Last Name: Jim
I tried Paint first and that worked quite well . Thanks "opened pics and opend Skew/shrink and changes % from 100 to approx 25% , saved them as new pic and it worked quite well
PostPosted: Sun Nov 01, 2009 12:50 pm
Last Name: Cox
If you try to "resize" an image in paint by grabbing the corner and dragging like how you would resize a window (Or anything else in Windows)-- it crops down the image..... It doesn't resize it....
What you gotta do is go into the Image menu and select "Stretch/Skew" Then you manually type in the % reduction in both the Stretch vertical and horizontal... and magically, it makes it smaller.
Paint is a bit of an anomaly in Windows -- it doesn't work like anything else Microsoft has.... In some ways, that makes it amazingly fast and useful (Because they seem to have forgotten it's existance... basically leaving it alone rather than mucking it up into something slow, bloated, and useless...)... In other ways, it is hinky and weird... but the Hinky and weird is predictable, stable, and fast...
I love Paint for this sort of duty. It's faster than any photo editor out there....
PostPosted: Sun Nov 01, 2009 1:28 pm
Thanks. Worked well. I had been trying to do it by going to "attributes", not "stretch/skew".
The only thing I don't understand is how to know you have resized to the proper size. When I save the pic and then right click and select properties, or go to attributes and check, it still says the pic is the same size as before resizing, which, of course, it isn't. :?
P.S.: Never mind, I figured it out. Operator error again. :oops:
PostPosted: Sun Nov 01, 2009 5:55 pm
Last Name: Shaw
City: Philadelphia
I still use XP so i use this though it doesn't work in the Newer Vista and windows 7.
PostPosted: Sun Nov 01, 2009 7:57 pm
I'm trying to understand how the OP's lack of information makes this a "*&*(**&%%$%$& site".
PostPosted: Sun Nov 01, 2009 8:04 pm
First name: Big
Last Name: Jim
It doesnt , thats just me goofin off bliss
PostPosted: Sun Nov 01, 2009 8:37 pm
I read, somewhere, that Vista and 7 have their own resizer built into the software.
PostPosted: Sun Nov 01, 2009 8:46 pm
Ya Mike, vista sucks :x :lol:
There is one similar to windows resizer for vista, it is VSO resizer and it works just as well. I'm sure there will be something free out there soon for windows 7.
Users browsing this forum: No registered users and 39 guests
