It is currently Sun Aug 10, 2025 5:22 pm
PostPosted: Thu Nov 26, 2009 11:10 am
Last Name: Charnock
Country: UK
Hi All
I have a FOX side bender partially completed on the bench and I have prepared a solid bending from from 6 pieces of 1" birch ply. I used an OM style template (no cutaway) to draw the shape of the form.
I am also building a mold for the same guitar from 4 peices of stacked 24" * 10" * 22 mm MDF.
The question is, do I make the mold with a slightly bigger circumference or is the size of sides plus any allowance for a bending blanket and slats insignificant.
Hope this makes sense ?
PostPosted: Thu Nov 26, 2009 11:32 am
Last Name: Charnock
Country: UK
Hi
I made my forming template first, so I guess it would work in reverse and make my mold slightly bigger. I suppose the end result is the overall size of the guitar is marginally bigger then my template.
I am sure that I also read on your instructions somewhere that the differenc eis only important on a cutaway ?
PostPosted: Thu Nov 26, 2009 2:20 pm
With wood being wood and each piece will bend a touch differently you want the bend pattern compensated a bit from the mold. Todd's advice is sound.
PostPosted: Thu Nov 26, 2009 2:32 pm
Last Name: Charnock
Country: UK
Todd
I see that you also make your bending form width just shy of the width of your bender, my bender width is currently 6" + 1/16 either side. My form is a good 1/2 thinner. Is worth making the width to match the bender?
PostPosted: Fri Nov 27, 2009 3:49 am
Last Name: Charnock
Country: UK
Hi
Yes, for the little extra effort I will probably build it out to somewhere near the thickness of the bender.
Users browsing this forum: Michaeldc and 40 guests
