It is currently Sun Aug 10, 2025 3:16 pm
PostPosted: Sat Nov 28, 2009 4:20 pm
I decided I didn't like the rope rosette on my new 6 and 12 strings so I redid the rosettes and then rebound them. Here's the fix...
Measure your soundhole with a dial caliper. Measure in several places to be sure. We are going to make a plug that fits snugly and has the pin exactly centered. Using a chunk of thick spruce, set the router for 1/2 the thickness and run it out 3/16" from your target diameter.
Rout inward till you hit your target diameter...
Run your router back out and cut through the spruce. Then glue a block on the inside for pin support...
Plug up your soundhole and get to work...
Install your new rosette. I elected to yank the teflon right away and fill with slightly tapered Coco to push the purflin out snug...
Sand it off and you are done...
PostPosted: Sat Nov 28, 2009 4:23 pm
Haans, the old one looked fine but the new one looks even better. By the way, how do you like the stew mac rosette cutter with the dremel? Its what I have but have not tried it yet.
PostPosted: Sat Nov 28, 2009 4:47 pm
Marvelous. Thank you, Haans!
PostPosted: Sat Nov 28, 2009 4:50 pm
Thanks Haans. I wondered how one might redo a rosette after the soundhole was cut.
PostPosted: Sun Nov 29, 2009 7:51 am
Thanks guys! It's very easy to make, quick (took me about 5 minutes), and as accurate as you measured the hole. I found that it cut the trim out and nothing else. Of course a good snug fit is essential.
Edward, The Stew-Mac jig itself is as good as any router jig. You have to seal the wood well to get a good cut, you should use very sharp downcut bits and don't rush. Make sure the pin is vertical, supported by a board underneath and a tight fit. Also make sure your Dremel is good...some of my old ones have the wobblies.
PostPosted: Sun Nov 29, 2009 8:17 am
Seal with lacquer?
PostPosted: Sun Nov 29, 2009 9:11 am
First name: Corky
Last Name: Long
City: Mount Kisco
Great tip, Haans! Thanks!
PostPosted: Mon Nov 30, 2009 7:23 am
Yes, Edward, lacquer works along with shellac or spirit varnish. I rub a couple of coats in with a rag. Most important is to wait till it's completely dry and hard. Heat gun judiciously used helps if you are in a hurry.
As Todd says, it should work with any router rosette setup.
PostPosted: Mon Nov 30, 2009 9:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Nice job Haans. Love the sealer tip. Gonna use that next time!
PostPosted: Tue Dec 01, 2009 10:49 am
Mike, I was kinda unclear, but I'd use lacquer with lacquer, and shellac or spirit with varnish. Not a good idea to mix finishes normally.
