It is currently Sun Aug 10, 2025 12:09 am
 Post subject: Double toppers
PostPosted: Mon Dec 07, 2009 11:50 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Any info out there on placement and construction of the Contreras style Double top? I know others are producing double tops...some with wood tops and others are doing composition. I just don't happen to have an old one laying around to take apart. It seems a second top is mounted just 1/4-1/2 in. above the back....
What is the soundhole size relationship and placement between the 2 tops. Is there any flaring or arch in the second top? Since the second top wouldn't a doesn't require supporting bracing for structure, what type of minor thin bracing would be necessary?
Mr. Curious,
Kent Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
 Post subject: Re: Double toppers
PostPosted: Mon Dec 07, 2009 12:25 pm
I could be wrong, but I think that the first Contreras double tops were simply a back made of top wood (cedar or spruce) with a thin outside veneer to protect it from damage and make it look like a normal back.
