It is currently Wed Jul 30, 2025 5:03 pm
PostPosted: Wed Oct 05, 2005 5:02 am
First name: Tom
Last Name: Dowey
City: Sudbury
State: Massachusetts
Zip/Postal Code: 01776
Is there any way to save these videos to my computer. I want to have them on my computer for future use. Is this possible? And is it legal?
PostPosted: Wed Oct 05, 2005 5:03 am
HI Tom -
This might be a silly question, can you right click on the link and (Save target as)?
PostPosted: Wed Oct 05, 2005 5:24 am
First name: Tom
Last Name: Dowey
City: Sudbury
Lance, that worked. I think.
PostPosted: Wed Oct 05, 2005 5:31 am
First name: Tom
Last Name: Dowey
City: Sudbury
No it didn't work. If I am connected to internet it works. I am looking to download and have on my computer.
PostPosted: Wed Oct 05, 2005 6:12 am
Sounds to me they are providing a streaming link and not a data download.
PostPosted: Wed Oct 05, 2005 6:58 am
Here is how you do it.
1) choose which version you want. High bandwidth or low.
2) when it comes up RIGHT click on it and select properties.
3) At the bottom of that box will be a URL. Overhighlight it and hit CNTL+C (Copy)
4) Open a browser window and paste (CNTL+V) that URL in the new browser
5) That will probably start your Windows Media Player
6) Once it begins to play in WMP simply do a FILE .. SAVE AS...
and you are good to go.
I have them all saved... I can get you a copy if you need them, but they are huge files... so they would have to go out via USPS.
Brock Poling38630.6660416667
PostPosted: Wed Oct 05, 2005 9:00 am
First name: Scott
Last Name: Thompson
Or another method, your browser saves it to its cache, so after playing, navigate to the browsers cache folder, find the file and cut and paste elsewhere on your computer. That is how I saved them.
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Wed Oct 05, 2005 9:43 am
First name: Tom
Last Name: Dowey
City: Sudbury
Brock, thanks so much. I used your method and it worked great. Thanks to you too Scott for the other method.
PostPosted: Thu Oct 06, 2005 5:06 pm
Scott, for those of us computer challanged would you explain how to "navigate to the browsers cache folder"?
Brock, I tried your method and the sound was there but the image was all diagonal lines once it started in WMP so I never tried to save it. Any suggestions?
PostPosted: Thu Oct 06, 2005 7:10 pm
[QUOTE=Roy O] Scott, for those of us computer challanged would you explain how to "navigate to the browsers cache folder"?
Brock, I tried your method and the sound was there but the image was all diagonal lines once it started in WMP so I never tried to save it. Any suggestions?[/QUOTE]
Find you internet cache directory (often in one of the 'Documents and Settings' sub-folders, although simply going through the options tab in your browser should reveal where it's hiding; worst case, search your computer for the word 'cache'). Then look for large .wmv files.
PostPosted: Thu Oct 06, 2005 10:19 pm
Hey Tom.... Roy's and Mattia's suggestion to find it in your cache is good. My guess is though by your description of the problem that you have not updated your player in a while.
See what version you are on and perhaps upgrade.
If that fails, PM me and I will help you get them.
PostPosted: Thu Oct 06, 2005 10:20 pm
BY THE WAY....
TODAY SHOULD BE THE DAY FOR A NEW FACTORY FRIDAY....
PostPosted: Thu Oct 06, 2005 10:38 pm
First name: Scott
Last Name: Thompson
Roy, the diagonal lines can happen with either method. Make sure you have the latest version of WMP, close out your web browser and try again.
Assuming your using windows:
Once the movie completely downloads, it will probably be in a folder called Temporary Internet Files
Easiest is to do a search for .wmv files through Start button-> search
Long explanation, but good to know:
If using Internet Explorer on the
Tools menu -> Internet options
->General tab
->middle section is called Temporary Internet Files
->Click on Setting button
->New window pops up, click View Files button.
This may take a few minutes for the cache folder to pop up depending on the size of you cache.
Look for .wmv files
You can sort the contents of that by size, name or date by using View menu, details
Scott Thompson38632.3258912037
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Fri Oct 07, 2005 3:42 am
Brock, you're right. I haven't updated my WMP, never saw the need until now. I'll give it a shot.
Thanks everyone for the guidance. I don't have the time to do this just yet but will give it a shot later today or tomorrow.
Roy
PostPosted: Fri Oct 07, 2005 4:09 am
In todays version of Factory Fridays they glue in their kerfing. If you watch
it, you will notice the clamps they use. Taylor designed their own to fit the
triangular shape of the kerfing better. You get even clamping pressure.
THEY ARE AWESOME. I live in San Diego not far from Taylor and when I
visited their factory I saw these simple clamps. I called customer service and
ordered a set. They weren't cheep, but they will sell a set. (enough to do
top and back simultaneously) They are in two widths. The smaller ones are
great around tight corners.
Andy
PostPosted: Fri Oct 07, 2005 6:06 am
Do you remember how much those were per set?
Do you get thick and thin ones in a set of them?
PostPosted: Fri Oct 07, 2005 7:00 am
Brock.
I am almost embarassed to admit how much I paid for the set, compared to
clothes pins, but they are great. Bill Collings uses them as well as several
other luthiers. I paid $175 for the set. It included plenty to do the back and
top sides simultaneously. It came with both sizes. The majority of them are
the thicker ones. When I took the tour of the factory, the tour guide
mentioned that they designed the clamps and they were so much better,
that other builders that saw them, wanted them. I called customer service
and had them in 2 days.   (800) 943-6782
Andy
PostPosted: Fri Oct 07, 2005 2:02 pm
I found it interesting that they did the kerfing out of the mould. I always leave it in the mold when I do the kerfing and figured it wouldn't hold its shape well if out. They sure make it look easy and the clamps are great. Can't afford them but if I could...
