It is currently Sun Sep 14, 2025 8:54 am
 Post subject: fret tang removal method
PostPosted: Tue Dec 22, 2009 7:09 am
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
After looking at the LMI tool for this job. Here's what I come up with. Once set-up the results are very repeatable. For the initial set-up
100_4392a.JPG[/attachment
I set the fence as close as I could and made a test run. I needed about .007 less to be ground off, instead of moving the fence, I used two strips of tape that come out to about .007 and stuck it on the side of the sled that rides against the fence.
This was just a quick set up to do the current guitar I'm working on now. An adjustable fence with some type of micro adjustment would be really nice if one was going to using this set-up quite a bit.
Hope this helps.
Jeff
PostPosted: Tue Dec 22, 2009 8:18 am
So how did you cut your groove in the marble Jeff?
Joe
PostPosted: Tue Dec 22, 2009 9:13 am
First name: Jeff
Last Name: Hewitt
Hi Joe,
Its sum type of plastic....I got it where I work (scrap that was being thrown away).
