It is currently Mon Aug 11, 2025 11:52 am
 Post subject: Dred back braces
PostPosted: Sat Dec 26, 2009 12:10 pm
I'm curious about the two lower back braces shown on the Martin dred plans that I have. Are there any advantages/disadvantages to using the lower, wider braces shown on the plans, compared to the taller, narrower braces shown for the two upper back braces?
 Post subject: Re: Dred back braces
PostPosted: Sat Dec 26, 2009 12:18 pm
The bracing change was done in the mid 80's. The lower wider braced I think allow for more involvement of the back. It was a warranty issue that caused the change . The newer design are stiffer . You will see more humidity movement with the lower brace so be sure you glue up in a safe range of RH.
PostPosted: Sat Dec 26, 2009 4:00 pm
Last Name: Cox
Do a Search for Al Carruth's posts on back bracing and the relative effects of Low/wide vs Tall/thin.
He has a couple interesting opinions on the subject based on his testing.
PostPosted: Sun Dec 27, 2009 10:03 am
Thanks John and John! I have been using the lower, wider back braces, but thought I would ask about the difference since it appeared that many have switched to the higher, narrower braces.
I think that I'll continue using the lower, wider braces.
