It is currently Sat Feb 22, 2025 11:52 pm
PostPosted: Tue Dec 29, 2009 12:01 am
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Is a tool tray on the workbench for guitar making useful, or a waste of good bench top space?
Seems a waste to me, but since I am about to build a new bench, I thought I'd ask for your experience/opinion.
Ed
PostPosted: Tue Dec 29, 2009 12:53 am
First name: duh
Last Name: Padma
Well Ed,
Some like, some don't
Depends on your working habits.
Most cabinet makers love them...me use to love them too, especially when using repetitive tools all day long, every day as is often the case with cabinetry. However in luthiery, it seems you use a tool and then don't touch it again for days or weeks or months and so like you really need to have it sitting there in that hole in yer bench just in case ...ya right.
When me built me last bench I left it out and don't miss it. But what me did was put 12 thin or shallow drawers in the side of the bench, holds all me chisels ( me do a lotta carving) and the tools that are used regularly. Also left off the heavy traditional cabinet makers end or tail vise...don't miss it ether. So me new bench is more like a 4.5' x 2 ft buffet with all them drawers and a 1.5 inch thick top. Big enough to hold an ax and the few tools being used. Oh ya its got 7 strings and tuners attached to the frame styles running just under the top which are then tuned to whatever type instrument me currently building. Helps me to have them sympathetic vibrations of whatever is being build coming from the table me working on.
So there be my take on benches.
Only advise....make it as strong and as solid as you can possible can...and then some.
But don't get carried away...its only a bench. laughing6-hehe
blessings
the
Padma
PostPosted: Tue Dec 29, 2009 12:58 am
Ed
I built mine without one Ed. If you don't need a major sawdust receptacle, then I personally don't see the need for one.
PostPosted: Tue Dec 29, 2009 6:19 am
Last Name: Rayner
City: Winnipeg
State: Manitoba
Zip/Postal Code: R3P 1B7
Yes, I would build a tool tray. I tend to place the tools I'm using on the surface of the workbench to the right of whatever I'm working on, but my tool tray is invaluable for always keeping a few tools and things that I want really handy - knife, awl, tape measure, small notepad, honing jig, and also a salmon tin that is a good place to store those little odds and ends that always end up on a workbench. An alternative might be to have a shelf immediately to the right of your normal working position (if you're right-handed) and just above waist height, to place tools currently in use and frequently-used items. I have one of these too, where I keep the most valuable tool - coffee - as well as a jar of pencils, a few small clamps, and a rechargeable drill.
"I must let my soul be my own judge."
6course.blogspot.com
PostPosted: Tue Dec 29, 2009 8:07 am
First name: Matt
Last Name: Rispoli
State: NJ
I think it depends on how big your work bench is going to be. If you space/bench is relatively small then you need to keep as much space free as possible. If you have room than a built in tray. I am sure it would be useful. If you are worried about dust collection cut out a piece and plexi glass and cover it when your not using it.
good luck
matt
PostPosted: Tue Dec 29, 2009 9:51 am
Ed what the Padma said - it all depends on how YOU like to work.
For me bench top space is at a premium, I can never have too much of it, so I hate clutter. I keep only the tools that I am using at the moment on the bench that I am working at. I am also concerned that I might put something down on a sharp tool and mess it up... [headinwall] :lol:
Dust is also my enemy and as such I never wanted to put my tools out on say holders or peg board on a wall because it is just going to get dusty. I have also wondered if anyone has ever knocked something like a sharp chisel off a wall and had it damage their work or worse - damage them..... :o :)
Most of all though it's back to how you like to work. I am still learning how I like to work and the only way it seems that this is possible for me is to get busy and build guitars. When I am building I begin to understand what would work better for me etc.
Here is my main bench, pretty spartan as you can see. To me a bunch of crap on a bench means that I have to do something and I can't relax.... :? You can see that I have only a few tools out that I am using at the moment.
Here is my tool tray of sorts - it's where I keep all the little crap that I do use frequently and want close at hand but not on or above my bench:
At the end of the day though what will work for you will be as the Padma says - what works for you.
PostPosted: Tue Dec 29, 2009 10:08 am
Other folks may opt for having the tools on a roll-around or in a drawer underneath. I found that over time I came to having multiple tool stands/holder plus a peg-board behind to be a better arrangement for the way I work. I found the roll around to always to be in the way or in the wrong place. A single tool tray took up too much space and I kept moving it around. I ended up making several lucite/plexiglass blocks with holes drilled in them for things like files and small chisels and small pokers/scrapers/etc-ers. These holders tend to drift around for a bit and then locate themselves in the least used places on the bench, mostly along the back splash. Larger things like big chisels and dikes and such go up on the peg board. All that being said, I ended up with only a few of these blocks with the most used tools in them. Job-Specific tools like reamers for bridge pins or fret saws and such go in the box with the related things for that specific job and are stored on my job-specific shelves. May not be what others like but it works well for me.
Alan D.
PostPosted: Tue Dec 29, 2009 12:37 pm
Last Name: Haney
good luck
matt
Good point. I should give some context. My shop is small, 8' x 20' with one wall containing two benches, each about 9' long x 33" deep (18' total bench space). To me, that is a lot of bench space, but I have no choice really. The benches are over the hoods of 2 cars (the noses of the cars poke through one wall into the underside of each bench! One bench will be at 38" and one at 43" (I am tall). There is room for a tool tray or two if they are useful. So far, I have not heard a good case for a tool tray for guitar building, which is what I assumed.
I may make one bench 24" wide which would give me more room to have a small 18" or 24" bench (fold up?) perpendicular in the center of a long bench. This would give me the ability to work on 3 sides of a guitar which I think is valuable.
Thoughts?
Thanks for all the helpful comments and pictures.
ed
PostPosted: Tue Dec 29, 2009 12:58 pm
the
Padma
PostPosted: Tue Dec 29, 2009 3:12 pm
First name: Hugh
City: Lake Oswego
State: oregon
I have 2 small benches. One gets only the guitar, the other gets the tools. That's the idea anyway. I kind of like the looks of that plastic tub shown in the picture, though.
Hugh
PostPosted: Tue Dec 29, 2009 3:25 pm
First name: duh
Last Name: Padma
Howard Klepper wrote:
the
Padma
Gee Howard,
Me the Padma is truly most honourd.
Me didn't hink that such a highly respected and well know luthier like yourself wood even have the time to read any thing that me posted. Let alone take the time to reply and then be asking me for clearification of me babblings to boot.
However since you do read my stuff, well then you know the drill... $20...in an envelope... to the Padma... C/O this here web site, and I'll get back to you on that. laughing6-hehe
As always
lessings
the
Padma
But you know Howard, must admit that was pretty good, me glad to see you have a humerous side.
PostPosted: Tue Dec 29, 2009 3:51 pm
Last Name: Shaw
City: Philadelphia
My benches don't have them. They are home made and i didn't think about them when building. But i do have and idea to add them since it would be nice to be able to push the chisels and whatever into them so when I am flipping instrument around I don't hit a tool i laid on the bench damaging the instrument. I was thinking of attaching mud trays to the ends of both sides..Mike
PostPosted: Tue Dec 29, 2009 4:45 pm
the Padma wrote:
As always
lessings
Now, was that a typo or ...........? :D
I have one in my bench. Sometimes I like it... keeps things I'm working with handy & below the "accident" plane of the bench. Sometimes I hate it... full of crap /dust / things I'm too lazy to put where they should be. Flip a coin, but I'm thinking my next won't have one.
Milton, ON
PostPosted: Tue Dec 29, 2009 6:47 pm
Before I got into this full time, I wanted a versatile bench, and liked the look of the one in the LV catalog .. so thats what I built .. two 14 inch wide slabs, each with two rows of 3/4 dog holes spread 7 inches apart, and int eh middle a tool trough, open at one end to sweep out dust and crap, but most of the time I just hit it with teh vac hose. I like it, other than at times it does collect too much stuff, but then you just clean it up, no different than a solid top that gets cleaned more often.
PostPosted: Tue Dec 29, 2009 10:51 pm
PostPosted: Tue Dec 29, 2009 11:26 pm
I have a humerous on both sides, actually.
PostPosted: Wed Dec 30, 2009 7:47 am
Last Name: Haney
TonyFrancis wrote:
Kia ora Ed,
I think the tool tray question is a good one. Different things work for different folks, so here is my two cents.
My main bench for guitar stuff isnt a proper German type cabinetmakers bench, its a simple pine bench without any vises or anything, although you could mount one I guess, but I have other benches for that.
Anyways, I dont like tool trays, they clutter junk. So I got this great idea from my friends in Germany who have a raised tool tray at the back of the bench - keeps everything clean but also close at hand. I dont have a proper picture of the bench itself but here you can see it I guess:
Another nice idea. Thanks for sharing Tony.
Ed
PostPosted: Wed Dec 30, 2009 12:22 pm
That is quite humerus.
PostPosted: Wed Dec 30, 2009 12:40 pm
First name: duh
Last Name: Padma
Wow Howard...
You really on the ball.
Shows you truly are paying close attention to me "rustic hillbilly approach" of posting to hopefully inspire, taunt and be dazzle you all with the BS* of me dangerous cognitions and philosophies, brilliant ideas, and babbling insanity.
I must sinsearingly thank you for such attention to this old fools babbling.
blessing
the
Padma
PostPosted: Wed Dec 30, 2009 3:36 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
Since my shop is horribly small (see last pic!) I came up with sliding storage that I think is going to be very helpful.
Using full exstension, side mounting drawer slides. They twist a bit when fully extended (only one slide per storage thingy) but I won't have them fully extended for more than a few moments at a time.
And this...is 2/3 of the full shop. Imagine not having a garage and all of that crap has to fit in here as well. GAH! wow7-eyes
cron
