It is currently Wed Jul 30, 2025 12:22 am
PostPosted: Sun Oct 09, 2005 12:10 pm
I had the pleasure of playing and looking under the hood of a Morris guitar at LB's Jam. This is one of three guitars that really stood out to my ears. Pretty conventional X braced top with the addition of a lower X in place of the two lower tone bars. Then there were two short lower tone bars off of the second X. It was an EIRW/Engleman fingerstyle guitar. Typically Engleman has a lower headroom but this thing was very responsive to a light touch and I couldn't get it to fizzle with a hard flatpick either. Anyone ever built one of these double X's?
tim...
PostPosted: Sun Oct 09, 2005 12:59 pm
Tim, every guitar I build is a double x.
Got any questions I can answer?
p
PostPosted: Sun Oct 09, 2005 1:29 pm
Paul, it appears that none of your braces are let in to the kerfing. Is that correct?
PostPosted: Sun Oct 09, 2005 4:41 pm
[QUOTE=Pwoolson] Got any questions I can answer?
p[/QUOTE]
Why are red gummy bears meaner than the green ones?
PostPosted: Sun Oct 09, 2005 7:18 pm
[QUOTE=John Mayes]
Why are red gummy bears meaner than the green ones?[/QUOTE]
Because they were double crossed
PostPosted: Sun Oct 09, 2005 8:16 pm
I have no experience with double x bracing, but I have read that some repair people refer to it as the "double cross" because it is so difficult to repair.
PostPosted: Sun Oct 09, 2005 8:56 pm
Yup, that's 100% correct. I tuck NO braces, top or back. If you look back in the arcives you'll probably find several discussions about why I do this.
PostPosted: Sun Oct 09, 2005 11:40 pm
Thanks, Paul,   and we're all waiting for your answer to John's question. Although, Dave's was pretty good.
PostPosted: Mon Oct 10, 2005 12:17 am
Well, it stems from an age-old rivelry. The green have been associated with the same conotations as green M&Ms. Thus making them MUCH more popular. So in a sense, the red gummi bears are red with jealousy. Wait, that doesn't make sense.
I could go down the "red gummi bears vs red/blue state" idea. You know, the fact that they are red makes them republican which naturally makes them meaner... But I shouldn't go down that road.
PostPosted: Mon Oct 10, 2005 4:04 am
I've played Paul's guitars and they are pretty loud and sound good, however I'm heading in the exact opposite direction with my new bracing, less = more... If you look at Cumpiano's latest work he is using less bracing because he's found that some things just aren't needed.
One reason I think Woolson's are so responsive is that since he's not letting into the kerfing he is allowing the top to move more at the edges, kind of like a speaker cone moves. I'm still letting in my braces but they are very thin at the kerfing point...
-Paul-
-Paul-
Patriot Guitars
PostPosted: Mon Oct 10, 2005 4:44 am
I'm with you on that Paul. I only let in the top brace under the soundhole, and I will stop doing that on this next guitar. Speaker cone philosophy.
I have seen double x braces in which none of the intersections interlock. One brace passes over the other without touching. Sort of a brace tunnel. The guitar sounded good.
PostPosted: Mon Oct 10, 2005 4:55 am
I call that style Fourex. In the Dos Equis style (IMO), the lower X's upper
arms taper down and end at the upper X arms, rather than crossing them
with additional lap joints.
IMO, Paul, you have a lot of wood there, and the scallop of the upper X is
too far forward (toward the soundhole). But if it sounds good and the top
doesn't dip in front of the bridge (wait ten years?), then ignore me.
PostPosted: Mon Oct 10, 2005 5:37 am
Paul, Is it an optical illusion, or is your bridgeplate dished-out in the center?
DES - Farwell, MI
PostPosted: Mon Oct 10, 2005 6:05 am
This is my usual bracing pattern, which you could say is a form of double X but with one of the lower X legs shifted to each side. I don't do the interlocking of the lower X with the finger braces as an integral part but it follows the same lines:
Alan Carruth has written, I think, on this forum and elsewhere about his use of the double X brace system
PostPosted: Mon Oct 10, 2005 6:13 am
Though I'd love to take credit for that type of crazy workmanship, alas, it's an illusion.
PostPosted: Mon Oct 10, 2005 6:21 am
...thus the reason this top was aborted. But it's all I have pics of.
Yes, too much meat and the scallop is too dramatic. Here's a design of what I've been doing with Quad Xs.
PostPosted: Mon Oct 10, 2005 6:33 am
[QUOTE=Dave White] This is my usual bracing pattern, which you could say is a form of double X but with one of the lower X legs shifted to each side. [/QUOTE]
Dave, it looks like an X-Y pattern to me. That's right--it's a BOY guitar!!
PostPosted: Mon Oct 10, 2005 7:35 am
I did a little test project a couple of years ago, comparing an almost-matched pair of guitars. They were Small Jumbos, maple with Sitka tops, and built for jazz. The customer wanted two that sounded almost alike, so I built one with 'standard' paralel tone bars, and one with a double-X pattern. Everytnig else on them was as close to 'identical' as I could make it, including acoustic measurements of the parts. I took them to the ASIA meeting in '03 and had a bunch of people try them out. I wrote up the whole thing for 'Guitarmaker' magazine a couple of issues ago.
Basically, in a noisy environement the two guitars were about equally well liked, but in a quite space most people liked the double-X. There did not seem to be any particular bias in terms of playing style. There were measureable differences between the two instruments that correlated well with the subjective judgements.
Since then I've pretty well switched to double-X.
PostPosted: Mon Oct 10, 2005 8:12 am
Al... Do you have any pictures of your bracing and some dimensions?? I've been using a standard parabolic, thin and high but I'm back at the experimenting stage and maybe I'll build 3 identical with the bracing being the only difference and see what I get...
I was going to do something similar to what Bourgeois is doing in that the treble X would remain a parabolic and the Bass side would be scalloped like a traditional martin brace. I was intending on keeping my standard bracing dimensions and my CF laminate in the bracing and see what I get...
Could be an interesting exercise
-Paul-
-Paul-
Patriot Guitars
PostPosted: Mon Oct 10, 2005 12:58 pm
Al:
Do you have any Chaldni patterns of the two guitars? Which one had the larger or 9nearer to a) closed ring? I would assume the double would have more nodes than the standard pattern but this isn't always as bad as it sounds ;)
tim...
