It is currently Mon Aug 11, 2025 6:12 pm
PostPosted: Thu Jan 07, 2010 12:32 pm
Hi, last week i reset the neck on an old martin 5-17t, all mahogany tenor guitar. The neck had probably been reset before with 'idontknowwhat'-glue, and I had to steam it pretty good. As usual, the steam gave the laguer a white haze. This has happened to me before, no biggie. But usually after a while it goes away, when the mosture escapes from the finish.
This time however, it has stayed in there for about a week. Do you guys have any tips on how to get it out?
Really thankful for any advise.
Best,
Lars
PostPosted: Thu Jan 07, 2010 12:40 pm
Buffing or vigorously rubbing the area with a cloth will often work. The heat generated by the buffing seems to be the key.
PostPosted: Thu Jan 07, 2010 1:22 pm
State: ON
If I remember right on the Stew Mac neck reset video they use a quick wipe with denatured alcohol (I think it was). Maybe someone can confirm this, or if I get the chance I will check the video before you give it a try.. The alcohol released the moisture and cleared up the haze.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Jan 07, 2010 1:29 pm
Cool! Will give that a try. Tried w naphta, but with no result.
PostPosted: Thu Jan 07, 2010 1:57 pm
First name: jack
If it's a lacquer finish, I'd say to spray a light coat of retarder/lacq.thinner; should remove any moisture trapped.
regards,
jack
PostPosted: Thu Jan 07, 2010 2:22 pm
I have removed that with a little of the courser hand polish - Meguiars number 2 .. then follow up with number 7 - the top layer of the finish seems to get that sometimes. If the overall finish isnt that shiny, the number 2 may be all you need ..it still leaves a decent shine.
PostPosted: Fri Jan 08, 2010 12:16 am
I have used Blush Eraser for this with good results.
PostPosted: Fri Jan 08, 2010 12:55 am
The stuff I've use for shellac flakes works well for this - Behkol
PostPosted: Fri Jan 08, 2010 5:45 am
Thanks guys, used alcohol, worked like a dream.
Users browsing this forum: Brad Goodman and 32 guests
