It is currently Sun Sep 14, 2025 10:51 am
PostPosted: Fri Jan 08, 2010 12:25 pm
Country: Estonia
Hi
Im newbie here.Im doing a refret job on a custom builted ibanez jem copy and there is a problem with fret slots being too deep(5mm).Do I need to fill these slots and what is the best glue for doing it?Does Titebond liquid hideglue good for it or do I need epoxy
PostPosted: Fri Jan 08, 2010 12:35 pm
Hi Juss - why do you want to "fill" the slots with glue?
Typically the frets are pressed or hammered in the slots and many folks use some glue to help lubricate the fret slot for the fret tang and to help hold the fret ends down.
I have not used the bottled hide glue but I know folks who use it for frets and I think this is probably a good idea. The part of the slot that has no fret in it just is left unfilled.
If you are talking about the exposed fret slot ends that you can see from the sides of the fretboard I have used black epoxy to fill these. I suspect that black CA, medium viscosity would be good too. Even glue with ebony dust if the fretboard is ebony will work just be sure to test out what ever glue that you use on scrap first and get the method down. Some glues will shrink back more than others too.
Welcome to the OLF!
PostPosted: Fri Jan 08, 2010 12:46 pm
As long as the width of the slots are correct (about .022") then you should be ok with a little titebond in the slot. If you are not using binding, you can fill the gaps on the edge of the fb w/ epoxy mixed w/ a little sawdust then sand them flush. I'd advise against epoxy to glue in the fret - it's so thick that it may keep you from seeing if the fret is seated properly, plus if you have to do a re-fret at some point, the titebond will not have bonded the fret to the wood so much that you can't remove it.
PostPosted: Fri Jan 08, 2010 5:04 pm
Country: Estonia
Thanks for your replys.
But doesnt the deeper(0.5mm) fret slots weakening the neck somehow.Because the fret tang height is only about 1.5 mm ,theres too much space left.
PS sorry for my bad english
PostPosted: Sat Jan 09, 2010 12:28 pm
I suppose you could fill the slots with epoxy then re-cut the slots - if you do that remember to tint the epoxy to the color of the fingerboard if the edges are not covered with binding.
PostPosted: Sat Jan 09, 2010 7:47 pm
Last Name: Garrish
I wouldn't worry about it. Once it's assembled you're talking about a small gap, under a metal shim, in a material being put into a compression load. That material's only significant for strength if it so happens that your frets are going to squish under the load (unlikely).
If you don't like the look of it from the side then do as others have said, or just use a lacquer or wax fill stick to fill the visible gap on the side.
Bob Garrish
PostPosted: Sun Jan 10, 2010 1:45 pm
Thats what I was thinking - the fret itself would keep the fingerboard stable and strong - you could make the case that the space under the fret could compromise tone - but I don't think it would be anything to be concerned about.
PostPosted: Wed Jan 20, 2010 8:31 am
Country: Estonia
Thanks for your replays
PostPosted: Wed Jan 20, 2010 10:36 am
There must be sufficient space under the fret when it is inserted so that the fret tang does not hit the bottom of the slot, which would prevent it from being fully seated. Others have addressed the strength issue, which is not a problem.
