It is currently Mon Sep 15, 2025 2:26 pm
PostPosted: Thu Jan 14, 2010 10:55 pm
First name: Carl
Last Name: C.
Hi,
I'm on my way in the a.m. to pick up the two colors for my first electric guitar build, and I'm worried about what to buy. I decided on using McFadden clear gloss, and I am unsure if I can use a lacquer over paint (oil-based or enamel).
I experienced in the past a mistake when I tried to use brushed lacquer over spray lacquer, and wanted to avoid a similar mistake.
Will the lacquer react with the paint, or do I need to go with black spray lacquer? My primary color is black, with a bit of a silver burst in it.
Thank you all for the helpful tips and answers on my previous two questions.
Carl from Texas
PostPosted: Thu Jan 14, 2010 11:21 pm
Last Name: Abercrombie
One strategy is to go to an autobody supply shop and get them to sell you what you need. Most of them can mix just about any shade you want and put it in an aerosol can. (They can also 'scan' a guitar to match the color.)
Black should be pretty straightforward, and they can sell you some sort of clear coat as well.
PostPosted: Thu Jan 14, 2010 11:49 pm
stardogcustoms wrote:
Hi,
Carl from Texas
Carl I can assure you that lacquer over enamel will cause the enamel to lift and seperate! :o laughing6-hehe Old commercial line in case you don't know what I meant.
The solvents in the lacquer will melt the enamel substrate and casue it to wrinkle to the point of ruin!
PostPosted: Fri Jan 15, 2010 8:39 am
Last Name: McGee
City: Belleville
State: Illinois
[hijack]Lift & separate. Yea... good stuff.
Anymore, I think I'd rather have everything all together.[/hijack]
Bad decisions make for good stories.
-------John
My blog - http://poplarmechanics.blogspot.com/
