It is currently Thu Jul 31, 2025 12:15 pm
PostPosted: Wed Oct 12, 2005 7:34 am
First name: Nelson
Last Name: Palen
I made up an order form for custom archtops in Word that tends to break up when emailed. The form was done using the "Forms" options in Word which allows electronic entry into the various fields. Wondering if someone can take me by the hand and tell me how to convert the form to another format such as Excel or perhaps HTML to eliminate the "break up" problem?
Nelson
PostPosted: Wed Oct 12, 2005 8:05 am
Nelson,
I use excel for my invoices. You should be able to just copy the information from your word document into excel. You will have to adjust some of the column widths most likely and then mess around with getting things set up but once you have it it will be stable.
I can send you a copy of an invoice if you e-mail me and you can use that as an example to get you started.
shane@highmountaintonewood.com
PostPosted: Wed Oct 12, 2005 8:55 am
First name: Nelson
Last Name: Palen
Shane--That would be helpful. (invoice copy).
Send it to npalen@classicnet.net
Greatly appreciated.
Nelson
PostPosted: Wed Oct 12, 2005 8:56 am
I have one I'll send you also....
Done. 5:59 pm
Don Williams38637.7505787037
PostPosted: Wed Oct 12, 2005 1:26 pm
It's on it's way Nelson.
Let me know if you need more help after you get it. I am no computer expert but I can usually struggle through these things.
PostPosted: Wed Oct 12, 2005 3:17 pm
Hey Nelson, let me know if you just want me to invoice you
Seriously another option is to set up your invoice in Word table format, then print to PDF format and send that as an attachment to your billing emails.Anthony Z38638.0132407407
PostPosted: Fri Oct 14, 2005 6:28 am
Depending on the version of Word and Excel you may also have the ability to save as HTML as well...Open the document or spreadsheet and do file, save as and see if HTML is an option. It has been there for the last few versions of Office. Office 2003 also gives you the ability to save as XML also.
PostPosted: Sun Oct 16, 2005 1:53 pm
First name: Nelson
Last Name: Palen
Shawn--I've tried saving as HTML but I get the message that parts of the Word file are not compatible with HTML. I used the Forms toolbar in Word for developing the form with items such as text boxes, check boxes and drop downs.
Nelson
Users browsing this forum: Bing [Bot] and 13 guests
