It is currently Tue Aug 12, 2025 8:25 am
PostPosted: Thu Feb 11, 2010 10:41 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
Hi everyone,
I need 1.0mm square plastic (or other inlayable type material) or smaller size rods, in varying colors, as well as black and white.
Does anyone know of a source for this type of thing?
Craig L
www.handcraftinlay.com
PostPosted: Thu Feb 11, 2010 11:48 pm
First name: Jim
Last Name: Hansen
You might see what these folks have
http://www.tapplastics.com/
Jim Hansen
PostPosted: Fri Feb 12, 2010 12:47 am
Craig,
Maybe http://www.professionalplastics.com
PostPosted: Fri Feb 12, 2010 1:11 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Craig, Could you use 1mm thick veneer (there's a lot of 0.042" thick stuff around) and cut 1mm wide strips? I do that kind of thing a lot for my marquetry work. I use my laser to cut them neatly.
I did a bit of an intensive web search for 1mm square plastic rod and came up empty handed. How about cutting up some Corian on your bandsaw?
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Fri Feb 12, 2010 2:02 am
Last Name: Garrish
Can you use round and just level it off (looks the same once inlaid)? Anything that small can't really be extruded square, to my knowledge. It's hard to find a plastics supplier that will even extrude plastic rod that small. 1mm would be the lower bound on what most equipment could do, and most places won't do under 1/8th, but I have a supplier that extrudes 0.06" for me to use as side dots. One roll of material is more black side dots than even the biggest factory could use in years, though!
Bob Garrish
PostPosted: Fri Feb 12, 2010 4:05 am
First name: Gary
Last Name: Palmer
Country: England
Plastic sheet and veneer are probably your best bet. You can then trim to suit your needs.
PostPosted: Fri Feb 12, 2010 10:06 am
First name: René
City: Bossier City
State: Louisiana
Try Online Metals.Com.(and Plastics Too) Looks like you would have to slice them from their sheets.
http://www.onlinemetals.com/merchant.cf ... &top_cat=0
René
Users browsing this forum: roby and 37 guests
