It is currently Tue Aug 12, 2025 5:27 am
 Post subject: Re: Stewmac Fret Nippers
PostPosted: Sat Feb 13, 2010 8:48 pm
Filippo
I would get the one for the big fretwire. It will be a bit loose to get a clean cut on the smaller fretwire, but if you can slip a small strand of copper wire in there as a shim it might work like a charm. If shimming doesn't work it would be back to the file or buy the other one.
PostPosted: Mon Feb 15, 2010 10:33 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I bought the medium size a few years ago. I use Stewmac's medium fretwire on guitars and narrow on ukuleles. It trims both sizes fine.
This is one of the few dedicated "luthier tools" that I would definitely buy again
PostPosted: Tue Feb 16, 2010 6:15 pm
I like (and have bought) a lot of Stew-Mac's stuff but I made my own nippers from a Radio Shack sheet metal nibbler several years ago and it's still going strong. For $47 bucks I could make 3 of them.
PostPosted: Tue Feb 16, 2010 6:22 pm
Me too.
PostPosted: Tue Feb 16, 2010 6:46 pm
I also made one - only took about 5 minutes with a Dremel cutoff wheel
PostPosted: Tue Feb 16, 2010 11:33 pm
http://www.radioshack.com/product/index ... Id=2289712
Instructions on modding it are in the MIMF library.
PostPosted: Wed Feb 17, 2010 11:27 am
I made one from a Harbor Freight nipper. I need to deepen the slot, but it works fine too. I do, however, have to use it only in one direction, or it will bend the fret slightly. I think I was less than perfect in my grooving of the plate.
I think the nipper, itself, was less than $5.00.
