It is currently Tue Sep 16, 2025 12:27 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Project SuperDiablo
PostPosted: Sat Feb 20, 2010 11:09 am
First name: Brett
Last Name: Smith
City: RTP
The centerline is obvious on the spalted flamed maple so I am working from that. Template attached, rough out the route with the forstner bit then clean up with the router. The main thing I hate is the little points the forstner leaves so I set the depth of the drill press a 1/8" high.
Image Image
Image Image
"Unseen eyes of inner life Will make your soul return"
Pictures - PhotoBucket
Blog - Guitar Logistics Blog
Website - Guitar Logistics Home
PostPosted: Sat Feb 20, 2010 11:10 am
First name: Brett
Last Name: Smith
City: RTP
It was a little tight. I had to install it with a dead blow hammer... should slide right together when I glue it.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:11 am
First name: Brett
Last Name: Smith
City: RTP
Neck pickup routed.
Image Image
Side dots installed while the neck is still flat on the edge. I used to forget this all the time. Then I was looking at Myka's build threads and realized I needed to do this earlier in the build.
Image Image
Image Image
First name: Brett
Last Name: Smith
City: RTP
Time to start some rough carving. Last time I fretted the neck first. It moved after carving. This time I am carving it first. After trimming some wood with the bandsaw I started in with the spokeshave. The birdseye maple started to tear out... so I moved to the sanding disk. Not my favorite way to do this but I am not risking a deep tearout or gouge mark.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:12 am
First name: Brett
Last Name: Smith
City: RTP
Still not completely finished. I think I am going to take another 1/16" off the back. It needs to be a little flatter also. Right now it is a nice round shape but the customer wants it to match my RG550.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:13 am
First name: Brett
Last Name: Smith
City: RTP
Finished cleaning up the lines on the body. I was going to start routing the body but got tired and decided to go drink instead. I always make mistakes when I get tired. Parts come in on Wednesday so I will probably try to finish up next weekend and get ready for finishing. I still have to thin the body but I need to get some other stuff ready because when I switch the bandsaw blade to resaw I have some other stuff to resaw.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:14 am
First name: Brett
Last Name: Smith
City: RTP
Not bad so far...
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:16 am
First name: Brett
Last Name: Smith
City: RTP
A few more...
Image Image
Image Image
First name: Brett
Last Name: Smith
City: RTP
Lay out the trem route for the wilkinson, studs, and pickups. 25.5" scale neck. The studs go at 25.25". I put the back of the bridge HB route at 24.75". Back of the neck route goes at 21.00"
Image Image
I used a 3/8" forstner bit in the corners to help prevent tear-out while routing. The HBs will be direct mounted to the body so I have to plan the depth of the route ahead of time.
Image Image
PostPosted: Sat Feb 20, 2010 11:17 am
First name: Brett
Last Name: Smith
City: RTP
I love mock-ups. The spalted top is a little soft that is why it has the clamp marks. No worries though as it is getting a carve. I really don't like PRS style carves... good thing I am getting paid for this one.
Image Image
Rear routes before I thin the body.. then after losing 3/8" from the back.
Image Image
PostPosted: Sat Feb 20, 2010 11:18 am
First name: Brett
Last Name: Smith
City: RTP
I used my binding bit to set the edge for the carve. Rough carved with the Grinder. And cleaned up with a 50 grit sanding disk.
Image Image
PostPosted: Sat Feb 20, 2010 11:19 am
First name: Brett
Last Name: Smith
City: RTP
After cleaning up with the DA and some 80 grit. I will work through the grits and fix a few little dibbles.
Image Image
Image Image
First name: Brett
Last Name: Smith
City: RTP
What is left... fretboard, fretting. I am not going to carve the back until the neck is glued in.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:20 am
First name: Brett
Last Name: Smith
City: RTP
Needed to tighten up the heal area on this.
Carved the back
First name: Brett
Last Name: Smith
City: RTP
Sanded the top out to 120 grit and cut the neck for the humbucker route.
PostPosted: Sat Feb 20, 2010 11:21 am
First name: Brett
Last Name: Smith
City: RTP
Working on the fretboard now. Start with 80 grit and the beam clamped in. After roughing in the 16" radius I flip and and true it up. Then I start working through the grits until it 320.
PostPosted: Sat Feb 20, 2010 11:22 am
First name: Brett
Last Name: Smith
City: RTP
Then a little steel wool... I stopped polishing the fretoard before fretting because I have to clean the glue after putting my frets in. I tried titebond on one neck and didn't like it. I am now using thick CA on the bottom of the fret. I really probably don't need it at all but sometimes I get paranoid...
PostPosted: Sat Feb 20, 2010 11:23 am
First name: Brett
Last Name: Smith
City: RTP
Couple more of the top with the neck fretted and trimmed up.
First name: Brett
Last Name: Smith
City: RTP
And the back...
PostPosted: Sat Feb 20, 2010 11:24 am
First name: Brett
Last Name: Smith
City: RTP
Gratuitous shots...
First name: Brett
Last Name: Smith
City: RTP
Drilled the input jack. Almost forgot the electronics holes. Now that would have made for an interesting afternoon had I glued the neck in without drilling those holes.
I am not sure which I hate more... filling fret ends or having to undercut fret tangs for hidden binding...
Image Image
PostPosted: Sat Feb 20, 2010 11:25 am
First name: Brett
Last Name: Smith
City: RTP
Finished fitting the control plates. Installed magnets and washers...
Image Image
Electronics holes drilled. I am keeping this simple as usual. One push pull knob. I might install a tap switch for the HBs if the customer wants one. I recess the input jack significantly to keep the lines clean and hide some of the plug.
Image Image
First name: Brett
Last Name: Smith
City: RTP
Recessed the tuners... I start with the 5/8 forstner then come back with the 3/8" forstner. Then I turn the thing over and drill out with the 13/32 within an 1/8" of the front. Not sure why guess I am trying to copy some of the factory necks I had in the 80s before companies started cutting corners.
Image Image
Image Image
PostPosted: Sat Feb 20, 2010 11:26 am
First name: Brett
Last Name: Smith
City: RTP
Mock up...
Image Image
Image Image
First name: Brett
Last Name: Smith
City: RTP
Back... going to glue the neck in when the weather clears up. Probably Thursday...
Image Image
Image Image
