It is currently Tue Aug 12, 2025 2:37 pm
PostPosted: Mon Feb 22, 2010 7:06 pm
First name: David
Last Name: Mrozinski
City: Essexville
Zip/Postal Code: 48732
Just wanted to post a pic of the precision router base and circle cutter I put together. The router support is tapped for a dremel. Just move the router support and the threaded rods between the router base and the circle cutter. The only thing not shown is a knob to tighten the circle cutter diameter adjustment pin.
Just looking for some feedback and thoughts.
Going to try it out routing for my first rosette installation next week.
djmrozinski@chartermi.net
PostPosted: Mon Feb 22, 2010 7:40 pm
Looks really good! [:Y:]
I bought mine in UK, but would have made one if I thought I could have made as good a job as your one looks to be.
Only thing I might suggest is the wing nuts you are using for depth adjustment might be a little tricky to adjust evenly - mine has large brass wheels with milled edges for fingertip fine adjustment.
Should easy for a man of your resourcefullness to make something similars for yours, if you find it a little tricky
I like the use of see-though plastic, mine is all metal.
Users browsing this forum: stumblin and 37 guests
