It is currently Tue Aug 12, 2025 3:20 am
PostPosted: Thu Mar 04, 2010 11:23 am
I'm building a cigar box banjo and it will use nylon strings. For the tail piece I would like to imitate the tie block on a classical guitar bridge. However I've only ever seen picture of a classical guitar bridge.
Is the tie block simply a rectangular piece of wood with string holes drilled through it, or am I missing an important detail?
Bob
PostPosted: Thu Mar 04, 2010 11:34 am
That's pretty much it, unless you want to get into multiple holes for each string. In reality, they're pretty simple.
PostPosted: Thu Mar 04, 2010 12:15 pm
What about multiple holes for each string?
PostPosted: Thu Mar 04, 2010 1:01 pm
Well, I have been using an 18 hole tie block for my classical guitars. Others like a 12 hole tie block. The 18 hole tie block keeps you from having any strings cross over the top of the block. The 12 hole allows the string to only cross the top of the block once. It just gives a neater look to the strung up instrument. Some don't like the look at all. Here is my last 18 holer.
PostPosted: Thu Mar 04, 2010 1:22 pm
I like the looks of your 18 hole.
PostPosted: Thu Mar 04, 2010 4:37 pm
Last Name: Abercrombie
WaddyThomson wrote:
It just gives a neater look to the strung up instrument. [/attachment]
It also affects the break angle of the strings over the saddle, which may be a good thing- or not. Some folks have also mused about increased chance of splitting the bridge with the extra holes, but I don't think this should be a big risk with a decent bridge blank. I think I'm going to give an 18-hole bridge a try next time.
Waddy-thanks for the pic.
PostPosted: Thu Mar 04, 2010 4:50 pm
The biggest problem I've had so far, is that some "e" strings break (Maybe that's why it's a break angle :D ). Not all of them, but it has been an issue with medium weight strings of some brands. Oasis Carbon trebles, and Galli Titanium medium trebles are two that come to mind.
PostPosted: Thu Mar 04, 2010 5:57 pm
I also use the 18 hole bridge, as do an increasing number of builders now, one refinement I make is to use a 1mm bone plate on the rear of the bridge.
PostPosted: Thu Mar 04, 2010 6:31 pm
Colin-
Thanks for that pic!
Looks like a great idea...another one for the 'steal this!' file.
PostPosted: Thu Mar 04, 2010 8:24 pm
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
Don't forget about the bone inlay in the tie block. It keeps the strings from damaging the wood.
John Nowicki
PostPosted: Fri Mar 05, 2010 2:40 am
First name: David
Last Name: LaPlante
The thing I like the most about the 18 hole bridge is the opportunity to do some nice inlay without the strings over it.
PostPosted: Fri Mar 05, 2010 11:02 am
Here's my newest. Trial saddle still not trimmed down yet.
Users browsing this forum: No registered users and 43 guests
