It is currently Tue Aug 12, 2025 1:41 pm
PostPosted: Tue Mar 02, 2010 4:48 pm
City: winnipeg
State: manitoba
Country: canada
I built a bouzouki last year, strung mando-cello, and the soundboard cracked on both sides of the bridge. Eight bass strings were too much for a thin spruce (0.085") soundboard. I have opened the soundboard with an iron and pallet-knife but can't get enough heat under the fretboard onto the Spanish heel.The fretboard has to come off and I don"t want to damage it.
My question is, what can I heat the titebond on the fretboard with that won't damage it. Any opinions would be appreciated.
Bob [uncle]
PostPosted: Tue Mar 02, 2010 5:16 pm
pull the frets, use a clothes iron about half setting ... wait for the heat to penetrate, go slowly with a pallet knife
PostPosted: Tue Mar 02, 2010 5:31 pm
City: winnipeg
State: manitoba
Country: canada
Tony:
That is what I was hoping to avoid. A hair dryer gun just doesn't have enough heat.
I may have to settle.
Bob
PostPosted: Tue Mar 02, 2010 5:48 pm
Yup, a clothes iron works great. Here's a tutorial I did awhile ago on how to remove a fretboard
Or you can use a side bending blanket if you have one. Some folks use a heat lamp too, but you really have to watch those as they can get really hot...
PostPosted: Wed Mar 03, 2010 4:02 pm
Something else that works is a heating blanket for mandolin sides if you have the setup. I've used it to remove bound fingerboards (with care) and it works great. Everyone has an iron though!
Brad Tucker
PostPosted: Wed Mar 03, 2010 4:11 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
You did not use expoxy, did you? ;)
PostPosted: Wed Mar 03, 2010 5:53 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Todd Stock wrote:
Epoxy will reverse with heat - more of it to get the neck off, but it will release.
Good to know - thanks!
PostPosted: Wed Mar 03, 2010 8:13 pm
City: winnipeg
State: manitoba
Country: canada
I have decided to work at the speed of light.
I will mask everything around the fretboard with aluminum foil and shine two 150 watt spotlights on it for long enough to soften the glue and use a pallet-knife to start the removal. I will try using a "B" string to see if it works well for the full length. I wound use heat-lamps if I had them.
Thanks for all the help. The various ideas and the tutorials have been useful and I will post any good procedures that come out of this project.
Bob [:Y:]
PostPosted: Fri Mar 05, 2010 11:22 am
Last Name: O'Melia
City: Huntsville
State: Alabama
How did the heat lamp work?
PostPosted: Fri Mar 05, 2010 4:00 pm
City: winnipeg
State: manitoba
Country: canada
How did the heat-lamp work? crummy.
The heat-lamp, using two 150 watt spotlights, could not deliver enough heat to soften the glue.
A hot air gun (hair-dryer) came close but not enough heat. A more powerful heater might do it.
The thing-a-ma-bob that did the job was a clothes iron on medium over the frets. I will find out later whether the frets have any problem. No scorch marks helps.
It looks like Tony was right about the iron. I hope that he wasn't right about the frets.
Now to design a bracing system that will give me good sound and be strong enough for eight bass strings.
Thanks for the advice.
Bob :ugeek:
PostPosted: Fri Mar 05, 2010 5:03 pm
First name: Tom
Last Name: West
State: Nova Scotia
unkabob: I'm suprised that the heat lamp did not work. I've removed guitar fingerboards that were glued with epoxy quite easily with a single heat lamp.
Tom
PostPosted: Fri Mar 05, 2010 5:16 pm
City: winnipeg
State: manitoba
Country: canada
Tom:
The fretboard just wouldn't heat up fromthe lamps at about eighteen inches. I may not have given it enough time to work but it just didn't pick up much heat.
Bob
PostPosted: Fri Mar 05, 2010 6:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I just had an idea (a bit late), but about a side bending heat blanket?
PostPosted: Fri Mar 05, 2010 7:40 pm
Last Name: Shaw
City: Philadelphia
I have used a household iron and a cake icer spatula. The long metal thin kind.
PostPosted: Fri Mar 05, 2010 8:16 pm
First name: Tom
Last Name: West
State: Nova Scotia
Bob: Think that 18" is not close enough.If you have to do it again try around 6" to 8" and moniter the heat closely. The dark color of most fingerboards takes in the heat very nicely and after a few minutes you should be able to work a palette knife or other thin tool in to help with the process.Try to get the tool in the full width of the neck then advance the heat and tool the full length of the board.You may want to put some sort of protection,cardboard wrapped in aluminum foil, over areas you don't want to heat such as the guitar soundboard. Good luck.
Tom
PostPosted: Fri Mar 05, 2010 8:18 pm
City: winnipeg
State: manitoba
Country: canada
I used two pallet-knives that I bought at Dollarama but the heat from the iron softened the glue in the handle of one and it came off. The cake spatula sounds more stable.
Bob
PostPosted: Sat Mar 06, 2010 10:37 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I'll second what Todd say. I took a fretboard off with a cloths iron that was adhered with epoxy. Seems like it took maybe twenty minutes or so of moving the iron back and forth and working a pallet knife.
PostPosted: Sat Mar 06, 2010 10:38 pm
First name: Chuck
City: Houston
Or a water bed heater.
PostPosted: Sun Mar 07, 2010 12:28 am
Last Name: Shanklin
City: Windsor
State: ON
I have a heating blanket that is specifically made for finger boards from Tom Durr at Doc's Mandolins. I have one for bridges also, as well as sides. His blanket system is great.
Sounds like a shameless plug.
Bob
Users browsing this forum: Ken Lewis, TimAllen and 47 guests
