It is currently Tue Aug 12, 2025 3:35 am
PostPosted: Mon Mar 08, 2010 7:13 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Hi,
I would like to know the best way to rubb out a gloss finish to a satin.
I'm working on an electric that has 16 coats of em6000 on the body and a Tru oiled neck.
Should I level sand starting with 800 and then 0000 steelwool or ????
Any advice would be helpful!!
I know I should have posted in the electric forum, but I figured I would get more answers here....
Thanks ,
Jeff
PostPosted: Mon Mar 08, 2010 8:20 pm
First name: Chuck
Last Name: Gilbert
I haven't used the water based finishes, but with nitro I start with P1200 and then P1500 wet/dry and then use Abralon pads in 2000 for a satin finish or then go to 4000 for a semi-gloss. After the 4000 I go to the buffing wheel and then swirl polish for a high gloss. Just stop when you get the look you want.
Hope this helps...
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
PostPosted: Mon Mar 08, 2010 9:27 pm
16 coats is a lot of finish. Good thing it's an electric.
Level with 600 3m gold (dry sanding), then 800 3m gold, then you could just move to 000 steelwool with mineral spirits as a cutting agent, then 0000 steelwool with the same. If you want a semi gloss you can use the 0000 with a paste wax, that's what this is.
PostPosted: Mon Mar 08, 2010 9:45 pm
My schedule is via a RO sander:
400 Dry
600 Dry
1000 Mirka Dry
2000 Abralon Wet
Old worn 2000 Abralon with Rottenstone wet
You can stop there or take it one step further with McGuires 7 or paste wax by hand
tim...
PostPosted: Mon Mar 08, 2010 9:50 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
FYI, I've been warned against using steel wool products on water based finishes (I think I read this in the EM6000 instructions)
Trev
http://www.PeakeGuitars.com
PostPosted: Mon Mar 08, 2010 10:10 pm
Good to know. Practice on scrap first as usual.
You could use the synthetic steel wool then....
PostPosted: Tue Mar 09, 2010 10:43 pm
The issue is using steel wool between coats on a water based finish (fibers get stuck between coats and rust). Shouldn't be an issue with rubbing out the finish. That being said, I'm a fan of the synthetic pads.
Eric
