It is currently Sat Aug 16, 2025 3:12 am
 Post subject: Show me your sound ports
PostPosted: Sat Mar 06, 2010 4:32 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
I'm looking for sound port ideas - so how 'bout showing them here.
I'm trying to figure out the best location and would also love to see some of your creative ideas.
I already have a maple veneer and ebony piece bent to reinforce my area. Just need to glue it in once I figure out where I want to position it. (Just need to cut off some of the excess.)
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Mar 06, 2010 4:42 pm
Hey Paul,
I've only built one gutiar with a sound port, it's oval shaped
check out some more pictures here
Location starts at the start of the upper bout curve. The oval is 4" long x 2" wide
PostPosted: Sat Mar 06, 2010 5:25 pm
Paul,
Here's a couple I did recently.
Maple
Ebony, before finish
PostPosted: Sat Mar 06, 2010 5:28 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Wow Pat - nice job on binding your sound ports.
Did you actually bend that - or is it a cut-out ring?
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Mar 06, 2010 5:42 pm
Last Name: Hammond
Heres' a couple:
I think this one should have been a little larger:
This one is bound with cocobolo and maple:
And finally
Have fun, be imaginative!
Mikey
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
PostPosted: Sat Mar 06, 2010 7:04 pm
Thanks.
They're bent. I broke a lot of ebony, even with SuperSoft.
PostPosted: Sat Mar 06, 2010 7:16 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Wow Pat - You got skills man.
I can hardly bend an ebony sound hole ring.
[:Y:] [:Y:] [:Y:] [:Y:] [:Y:]
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Mar 06, 2010 7:22 pm
Hey Paul, here's my first although I'm working on #2 tonight.
PostPosted: Sat Mar 06, 2010 7:35 pm
Last Name: Ensor
City: Springfield
State: Missouri
I usually do an oval shaped hole with a rounded over edge, but sometimes I try new things too.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sat Mar 06, 2010 9:33 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Wow Chris,
The one with multiple holes is pretty mazing.
How's the sound from it?
Are you using a standard sound hole on the front?
And to others - how much compensation did you do to your primary sound hole to account for the sound port?
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Mar 06, 2010 10:24 pm
I cheated. It was laminated. :D
PostPosted: Sat Mar 06, 2010 10:27 pm
First name: duh
Last Name: Padma
Sound ports eh.
Well me got a hole in one once.
SEE...
Didn't do nuthin for me score.
duh
Padma
PostPosted: Sat Mar 06, 2010 11:21 pm
First name: Evan
Last Name: McCartney-Melstad
Evan McCartney
PostPosted: Sun Mar 07, 2010 10:49 am
Last Name: Ensor
City: Springfield
State: Missouri
Thanks Paul. I like the sound from that padauk guitar. That one is interesting because it has a tailpiece and a cantilevered fingerboard. But yes, it does have a standard sound hole in the top. All of those things made for a very loud guitar with extremely long sustain. Overall, that one is pretty balanced from string to string as well.
Whenever I put soundports in, I don't adjust my sound hole at all. I leave it the way I normally do it. That seems to work for me.
PostPosted: Sun Mar 07, 2010 11:20 am
It seems that ovals and circles are the "go to" shape.
I do adjust the main sound hole for some of the additional square inches the port provides but not all. However, since the reports about adding the ports improving the sound of supposedly already properly sized instruments I am beginning to wonder if I should.
Greg N
PostPosted: Sun Mar 07, 2010 11:48 am
I did not compensate the tops sound hole at all for the sound port.
PostPosted: Sun Mar 07, 2010 11:58 am
I've done a few...
PostPosted: Sun Mar 07, 2010 7:45 pm
Not quite finished this guitar yet, it's in need of a coat of jam but it's my first with a soundport.
Veneered with birdseye maple and a black purfling & a curly maple "core" which doubled as an inside patch.
Nick Oliver
http://www.oliver-guitars.com
PostPosted: Sun Mar 07, 2010 9:26 pm
Here are several designs that we use:
http://mcknightguitars.com/soundports.html
tim...
PostPosted: Mon Mar 08, 2010 1:02 pm
Lots of great shapes... the "guitar pick" one is inspired Tim.
Here's the only one I've done.
Milton, ON
PostPosted: Tue Mar 09, 2010 4:23 pm
Last Name: Livermore
State: Minnesota
Here's mine. I put it in pretty much every guitar because I REALLY enjoy what it does for the tone I can hear as I play.
It is reinforced with a piece (or three or four if it won't bend) of side material running the grain perpendicular to the side. Then cut the port with a dremel. Then sand/file so that the reinforcement material can not be seen from the outside.
PostPosted: Tue Mar 09, 2010 5:32 pm
Greetings.
Q from a non-luthier here. What does the presence of sound ports do to the overall tone, especially what is projected from the front sound hole? Somehow, I always imagine sound ports as having a detrimental effect on the overall voice, but again, not a luthier.
Insanely curious, tho.
Kind regards,
-0.9
PostPosted: Wed Mar 10, 2010 9:36 pm
State: Minnesota
play a guitar with a port in it sometime.
It's amazing this hasn't caught on long ago.
Some say the tone is enhanced out front.
Some say it is diminished.
I say I really don't care because the guitar sounds so dang good to me.
Plus I'm finally not at the mercy of the sound man to keep my acoustic loud enough that I can hear it above the drums, bass and piano.
PostPosted: Thu May 06, 2010 4:05 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Wow! Great post. I've got to try a sound port.
Ed
PostPosted: Thu May 06, 2010 5:37 pm
Last Name: Hodge
Here a quick fuzzy and dirty shot of one I have in WIP. Better photos to come in the near future in a new thread. ;)
Bill Hodge
