It is currently Tue Aug 12, 2025 3:35 am
PostPosted: Thu Mar 11, 2010 12:21 am
I'm making a wood body block plane from a kit. The instructions say to finish
with Tung Oil. They don't mention the sole of the plane. I'm wondering if it's
a good idea to use Tung oil on the sole, or any finish there at all. I'm thinking of using
Tru Oil since I already have that for the rest of the body.
TIA,
PostPosted: Thu Mar 11, 2010 2:10 am
Leave it without finish. Anything you put on will rub off and probably mark the surface you are planing. The best finish is a very sharp scraper to get the sole flat.
PostPosted: Thu Mar 11, 2010 4:02 am
Last Name: Abercrombie
It depends a bit on what wood is on the plane sole. Traditionally, better-quality wood-bodied planes had lignum vitae or other hard/waxy woods on the sole to make them somewhat 'self-lubricating'.
I'd follow Sebastian's advice and leave it unfinished or use a penetrating-type oil like tung oil or so-called 'Danish' oil. Tru-Oil is actually more like a varnish, so I would not use that as it will certainly wear off quite quickly and cause problems.
PostPosted: Thu Mar 11, 2010 12:54 pm
Todd, what's "PU"?
PostPosted: Thu Mar 11, 2010 2:41 pm
crow-duck wrote:
Todd, what's "PU"?
Polyurethane glue- it sticks to oily woods quite well.
PostPosted: Thu Mar 11, 2010 2:55 pm
Thanks for the update on "PU", polyurethane glue.
Now, what's an example of "PU"? Like, Elmers, etc.?
TIA,
PostPosted: Thu Mar 11, 2010 3:20 pm
TIA,
Elmer's Ultimate High Performance Glue
Lepage Ultra PL Premium
Gorilla Glue (Polyurethane- not Gorilla 'Wood Glue' which is a standard PVA glue)
PU glues tend to be clear amber, honey-consistency liquids that require water to cure. Excess glue squeeze-out usually foams. Not gap-filling.
PostPosted: Thu Mar 11, 2010 3:54 pm
Correction- The Lepage Premium PU is colorless.
Users browsing this forum: No registered users and 47 guests
