It is currently Tue Aug 12, 2025 9:59 am
PostPosted: Fri Mar 12, 2010 4:12 pm
I'm digging into Somogyi's "Making of..." book and am intrigued with his method for installing binding and purfling at the tail wedge. Essentially he installs the tail wedge purfling and then finally the wedge after the top and back are bound, and miters the side purflings in place with what appears to be about a 1/16" chisel.
All that to say, any good recommendations for very narrow chisels? I've found at least one 1/16" chisel at Japan Woodworker but thought I'd pick your brains for other suggestions. I've also heard of folks grinding their own small chisels from old files and whatnot. What's involved with that process?
Jon
PostPosted: Fri Mar 12, 2010 4:29 pm
I have used a belt sander, very judiciously, to make an O-1, 1/8th" Ashley Iles or two into a 1/16th". Lie-Nielsen sells a 1/10th"-I haven't looked lately to see if they now offer it in the recently released O-1 line. I have the A-2 and it is a great piece, but around $55-60 USD plus shipping. I was in contact with L-N a great deal then on some sharpening deals and got one of the first-maybe 3-4 years ago and I rarely have to hone it--even when it bumps into dried glue. It is listed in their mortise chisels. I have 1.5mm and 2mm in some Japanese chisels that are also reliable edge holders-sacrilege here-I glue the rings on and smooth the tops. Thus, I have been suspended indefinitely from the Wonderful World Of Handtool Elitism-ain't that a durn shame? It's a tough room. laughing6-hehe Mike T.
PostPosted: Fri Mar 12, 2010 4:36 pm
LMI has some narrow chisels. 2mm I think.
PostPosted: Fri Mar 12, 2010 4:37 pm
Highland Woodworking sells a Hirsch 2mm chisel that is pretty nice. I have one, and love it. It would be easy to grind it down smaller than that. I use mine all the time. It's tall enough to keep from flexing much as you use it. Nice little chisel.
http://www.highlandwoodworking.com/hirs ... hisel.aspx
PostPosted: Fri Mar 12, 2010 7:48 pm
Lee Valley has a 1/16" Veritas detail chisel that is excellent if a little pricey. They also have some Japanese carving chisels that are much cheaper and work great as well.
PostPosted: Fri Mar 12, 2010 8:03 pm
I've made small chisels from Swiss jeweler's gravers, which come in various shapes and sizes. They usually need a little regrinding and a handle. It's been a while, but I used to get them from a jeweler's supply.
PostPosted: Sat Mar 13, 2010 9:23 am
Thank you for the tips everyone, that gives me a lot more options to consider.
At Japanwoodworker.com I found this one, a 1/16" white steel Matsumura bench chisel.
I'm guessing if you use a belt sender to grind a custom size you would have to be real careful not to let it get too hot, is that right? I found one site where a guy would buy "music wire," which I assume is piano strings of some kind(?), and work it into micro-chisels for carving.
PostPosted: Sat Mar 13, 2010 6:59 pm
Music wire is medium carbon steel that is medium hardened. It would work, I guess, but not hold an edge like well hardened and tempered tool steel.
PostPosted: Sat Mar 13, 2010 8:50 pm
I have a long, nice one from LMI (1mm), another nice long one ("Pfeil", 2mm, from local tool shop) and two short cheap ones (2mm and 1.5mm) which I made from steel nails. All four of them work fine. The "nailies" hold the edge pretty well, I was really surprised when I started to use them (well, I never removed a lot o wood with them though :mrgreen: )
Users browsing this forum: Cal Maier, Chris Pile, ptourin and 23 guests
