It is currently Tue Aug 12, 2025 3:27 am
 Post subject: Glue for neck heel
PostPosted: Sat Mar 13, 2010 8:43 am
I prefer to use a one piece neck due to grain incontinuity with a built up heel. But, it is not always posible to aquire a blank of sufficient size when using a non-mahogany wood for the neck. For puposes of this discussion, I am refering to a neck built of a 1x3 quarter sawn piece with a scarf joint and a stacked heel.
What type of glue do you use on the heel with a dovetail neck joint? I am thinking of potential delamination problems during a future neck reset.
Chuck
 Post subject: Re: Glue for neck heel
PostPosted: Sat Mar 13, 2010 6:35 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Chuck -all the modern (Titebond,Elmers,Lmii) HHG & Fish glue will be fine -as long as you make good glue joints.
Otherwise epoxy is neede to fill gaps.
Mike Collins
PostPosted: Sat Mar 13, 2010 6:57 pm
Chuck brings up a potential issue. Traditionally, built up heels were used on classicals without dovetail joints, and dovetails used on guitars without built up heels. I haven't seen any delaminating on the couple of multipiece necks (longitudinal laminations) that I have steamed out that I built with original Titebond as the glue. Fish glue would probably be the most prone to separating from steaming. If you want to be safe, use urea-formaldehyde or resorcinol, which are pretty impervious to moisture and would take a lot more heat to separate than you use when steaming the joint.
PostPosted: Sun Mar 14, 2010 8:49 am
Thanks for the replies Mike and Howard. I have a few built up neck heels that I used titebond on with a dovetail joint. Just never thought much about resetting back then. What do you think about polyurethane glue?
Chuck
PostPosted: Sun Mar 14, 2010 1:25 pm
I have used it a couple of times successfully, but I've read that it has a very short shelf life, and lots of people have had problems. Repeat earlier suggestions.
PostPosted: Sun Mar 14, 2010 4:34 pm
Thanks Howard, I'll look into the urea-formaldehyde glue, never used that before. Resorcinol may be a little dark, not sure if it will be noticeable. I did a test glue up with polyurethane (Gorilla glue brand) on surfaced spruce 2x4's, no noticeable glue line, and easy to work with as long as you wear gloves.
Chuck
Users browsing this forum: No registered users and 50 guests
cron
