It is currently Mon Sep 15, 2025 11:30 pm
PostPosted: Sun Mar 21, 2010 11:05 am
City: LV
State: NV
I've been lurking here for a while, and slowly working on this project for a friend. I decided a little too late to document the progress, but there's still some cool progress pics.
If anyone sees red flags, please let me know before it's too late! ;)
Basswood body, Maple/Wenge set neck (a la Universe), 7-string, multiscale (24.75-26.25", 12th fret perpendicular), tele-style bridge.
There are more images in the photobucket link.
Bucky
PostPosted: Sun Mar 21, 2010 11:12 am
City: LV
State: NV
Angled my jigs with popsicle sticks. Use height of 2 sticks (4mm), desired angle (0.88), and SOHCAHTOA to determine where on the jig the sticks should be (11" out).
The bridge will be like a tele, but I wanted the fretboard to rest on the body like an LP, thus the need for an angle. The calculation was string height drop is 3mm from bridge to 22nd fret.
Image Image
Image Image
pocket looks really clean to me.
PostPosted: Sun Mar 21, 2010 11:21 am
City: LV
State: NV
Next we create a razing jig to level off the body at the angle of the neck, so the fretboard will sit flush.
Image Image
Image Image
PostPosted: Sun Mar 21, 2010 11:48 am
City: LV
State: NV
I decided to put an angle on the heel, instead of the perpendicular heel on the LP.
Image Image
Image Image
PostPosted: Sun Mar 21, 2010 12:00 pm
City: LV
State: NV
The neck build was wasteful and not documented. I did have some foresight and didn't cut the headstock angle all the way up! This way, I could access, measure and drill from a good place, to a perpendicular surface. The headstock is scarfed, but the join should be higher than the tuners (if I were worried about a compromise in integrity).
Channel was routed, headstock face cut with the bandsaw, then belt-sanded. Due to a limited knowledge about what I'm doing, the trussrod adjustment nut will have to be extended.. :evil:
Image Image
Image Image
Image Image
More to come soon, I hope.
Bucky
PostPosted: Sat Apr 03, 2010 7:50 pm
City: LV
State: NV
Tenon an apparent success!! bliss
BTW guys, how tight do I want the fit? Melvyn Hiscock says "tight enough not too fall out, but not so tight it forces all the glue out." If I place the body on the bench, I can press the neck in with my thumbs, but it requires all my weight. This ok? There's really great transmission from the neck to the body, and vice versa - when I knock anywhere on it, it just sounds huge. What a thrill!
I also would like some input on my heel options. There's the Les Paul style and the neck-thru style that's a smooth transition from body to neck. Are there others I'm not thinking of? Anyone have advice for how I should approach it based on the construction?
Thanks a lot.
Image Image
Image Image
PostPosted: Wed Apr 21, 2010 11:24 pm
First name: Raymond
Last Name: DeGennaro
State: IL
Zip/Postal Code: 61008
Nice! It's always good to see another multi-scale build.
Ray
PostPosted: Sat Nov 06, 2010 10:40 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Yeah, how's it going?
Looks perfect so far.
PostPosted: Sat Nov 13, 2010 1:33 pm
City: LV
State: NV
Hit a brick wall. :(
The machine shop I hired to make the bridge & fretboard are giving me the friend discount, which also means it's done when the shop business is slow. So now we wait.
Thanks for the interest - I'd nearly forgotten. ;)
PostPosted: Sun Nov 14, 2010 10:40 am
I can only encourage you to experiment with http://www.ekips.org/tools/guitar/fretfind2d/ and make your own multiscale fingerboard. I used this utility to print a template that made my cutting jig and cut the fretboard. For the jig I used two pieces of aluminum angle and cut angular slots for the cheap backsaw http://www.harborfreight.com/japanese-flush-cut-saw-39273.html with a kerf that fits stew-mac fretwire nicely.Image
I got splendid results on maple.
Anything too stupid to be said is sung. -Voltaire
