It is currently Wed Aug 13, 2025 10:17 am
PostPosted: Tue Apr 06, 2010 1:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I recently used a backstrip from LMI (http://www.lmii.com/CartTwo/thirdproduc ... Backstrips, B16B, Cheveron). Really liked the color match. But after sanding board to 0.1", the whole thing simply split in half (along the centerline of the purfling). I even laminated the other side! Anybody ever have this happen? Suggestions?
PostPosted: Tue Apr 06, 2010 1:18 pm
First name: Tom
Last Name: West
State: Nova Scotia
Mike: Have used LMI's backstripes but not this one .I've used B120B a number of times and have not a problem.I put these in when I join the top and then after sanding to thickness I flood both sides of strip with thin CA glue. Knock on wood I have not had a problem YET....!!!
Tom
PostPosted: Tue Apr 06, 2010 4:01 pm
Last Name: Abercrombie
Mike-
Did you inlay the backstrip or include it (sandwich) in the back glue-up?
When you say that you 'laminated the other side' - was this your cross-grain back seam reinforcement?
Can you get the seam to close for re-gluing (and more reinforcement)?
PostPosted: Tue Apr 06, 2010 4:10 pm
Yup, i've had those problems with the large Washburn like strip. I cyano'd them and still had problems. I've stopped using them as part of the glue up, and now rout them in. I also have taken to glueing the inside spruce center strip in with industrial epoxy. No more problems...
PostPosted: Tue Apr 06, 2010 9:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Very dissapointed. I will recover the back, but will never use a premade strip that has an obvious failure mode down the center line. Only way I would use it is as an inlay.
PostPosted: Tue Apr 06, 2010 9:23 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
But I do appreciate the replies. If you look at a lot of the premade strips, many do not have a failure mode down the center. Note to self.
PostPosted: Tue Apr 06, 2010 9:30 pm
Mike, I've used at least a hundred of them and have never had a problem. After I trim the back, I usually take the scrap cutoff piece and purposly break it. Most often, the 2 halves will break at the seam of the backstrip, not the center. I think you got a bad strip.
Mike Franks
www.mjfranksguitar.com
PostPosted: Tue Apr 06, 2010 10:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Realy? U think bad strip?
PostPosted: Wed Apr 07, 2010 6:36 am
Country: Romania
The only decoration I somewhat trust to be sandwiched contains simple wood and veneers, and I go at great lengths to ensure very good joints. And then when I plane and scrape the back thin I always make sure not to pull on the seam, but push towards it or at least parallel, if that makes sense. I think the marquetry stuff is safer if inlaid in a routed channel. I would not sandwich it.
Build log
Users browsing this forum: Gasawdust, rbuddy and 15 guests
