It is currently Fri Aug 15, 2025 10:22 am
 Post subject: naptha question?
PostPosted: Wed Apr 28, 2010 10:41 am
I often see naptha referred to in the forum, but seems to be a bit tricky to source locally in UK.
Would lighter fluid be useable, say to release a veneer from double sided tape (solid/radial rosette construction)?
Thanks in advance for any help.
 Post subject: Re: naptha question?
PostPosted: Wed Apr 28, 2010 10:44 am
Yep, it is the same thing as naphtha.
White gas, Coleman camping fuel. Do you have these ?
I could be wrong but I don't think lighter fluid is white gas. Sure doesn't smell like it.
Link
PostPosted: Wed Apr 28, 2010 12:31 pm
Last Name: Abercrombie
Lighter fluid works fine for removing tape 'goo' - whether to release veneer or to clean residue from a finish (though I try to test finishes before hitting them with solvents...).
'Naptha' seems to be a pretty 'flexible' term- I'm not sure that white gas, naptha, coleman fuel, VM&P naptha and lighter fluid are all the same- at least in Canada.
Lighter fluid does come in a can with a convenient spout, so that's one advantage! [:Y:]
PostPosted: Wed Apr 28, 2010 12:58 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Just remember to wear gloves when using it.
It's slow evaporation rate & the fact that it is a coal-tar product can cause
some health problems .
The more your in contact with it the more gets absorbed into your skin.
For your liver & other organs to clean out.
Mike [:Y:]
Mike Collins
PostPosted: Wed Apr 28, 2010 1:03 pm
Good advice.
I keep boxes (nitrile and latex) of gloves handy, and use 'em.
PostPosted: Wed Apr 28, 2010 5:03 pm
Thanks to all for your help, looks like lighter fluid is is.
Thanks very much for the safety tips as well, it's good to know what's required.
PostPosted: Wed Apr 28, 2010 7:05 pm
here's a link: http://fuel.papo-art.com/ to a list of fuel names for various countries.
Naptha is called shellite, White gas, or Mobilite in Australia for example. All pretty much the same stuff though.
PostPosted: Thu Apr 29, 2010 12:08 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Don't know if it's true, but someone told me that camp stove fuel has an oily additive to prevent corrosion on the inside of the tank.
I'd like to know for sure, 'cause coleman stove fuel fuel is available everywhere. I have to order naptha from the nearest Mohawk distributor.
PostPosted: Thu Apr 29, 2010 7:18 am
Winsor & Newton Artists White Spirit is labelled as Naptha on their data sheet (and on the bottle, I think).
Available from art shops around the UK.
Jon
PostPosted: Thu Apr 29, 2010 9:34 am
Thanks - found Coleman's and Windsor and Newton product, both £5-6 a litres (1.7 pints or so) + P&P in UK.
