It is currently Thu Aug 14, 2025 11:32 pm
PostPosted: Fri May 07, 2010 8:55 am
I'm having trouble locating good quality bits between 1/32" and 1/8" with a 1/8" shank, where do you guys order them?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri May 07, 2010 9:32 am
Our ideas of good quality may differ, but here's the guy I use
http://www.smallwonder-music.co.uk/shop ... p-123-454/
Formerly JJH
PostPosted: Fri May 07, 2010 9:41 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Laurent,
Unless you go to carbide it's hard to find end mills that small on anything but a 3/16" shank. There is a company by the name of Richards that makes a lot of high quality end mills and another by the the name of Micro. Either of those guys should make something in HSS on an 1/8" shank. I think you can find those in the MSC catalog. Carbide is a bit more but you can get anything you want, up to 1/8", on a 1/8" shank. Robb Jack makes carbide in fractional sizes if you care to cut your fret slots on a mill. Do need higher speeds and better rigidity when using the carbide vs HSS.
Tim
PostPosted: Fri May 07, 2010 9:42 am
I use mostly the downcut bits SM sells. I bet you have tried them, what don't you like about them?
PostPosted: Fri May 07, 2010 9:45 am
http://www.precisebits.com/
Everything you need and great, knowledgeable people. They even have special bits for fret slotting.
PostPosted: Fri May 07, 2010 9:59 am
I'm another fan of Precise Bits, also Robb Jack has great bits.
PostPosted: Fri May 07, 2010 10:40 am
I ordered my last batch (3 flutes) from precisebits and they are great, I would order again with no hesitation
This place:
http://www.cetdirect.com/catalog/index. ... =1&sort=3a
seems cheaper but I have no experience with them.
Burton
Brookline, MA.
PostPosted: Fri May 07, 2010 11:03 am
Last Name: Shanklin
City: Windsor
State: ON
Laurent
I buy my small end mills from this ebay seller "foztigrenb". Good selection of very small (and large) carbide end mills, with great prices and very fast shipping.
Bob
PostPosted: Fri May 07, 2010 11:07 am
http://www.bqtool.com/
these are carbide and I use these . They are industrial quality.
PostPosted: Fri May 07, 2010 11:17 am
Last Name: Abercrombie
I've bought from http://drillbitcity.com/ and had good service, but I have no idea how the quality stacks up against the competition.
PostPosted: Fri May 07, 2010 11:30 am
Usually MSC.
PostPosted: Fri May 07, 2010 12:02 pm
Thanks!
Laurent Brondel
PostPosted: Fri May 07, 2010 12:33 pm
Just on bits for rosettes and other delicate routing-if you do 1/4" shank, never count Lee Valley out. I have gotten extraorinarily clean cuts for headstock inlays in my 44T(I have the full collet set) Foredom and in my PC310(said goodbye to a nice 1/16th LV bit learning the 310 chuck).They don't offer a bit that will do typical fret tang cuts, though. Otherwise, in my 1/8th collet, I, too, have done well with StewMac.
PostPosted: Fri May 07, 2010 1:56 pm
Acco and Hertzel spiral cut carbide end mills have worked well; both available from MSC.
PostPosted: Fri May 07, 2010 4:03 pm
Last Name: Garrish
On 'not-metal' I only use PreciseBits. Their stuff is pretty much untouchable in that arena so far as quality goes.
That said, if you're feeding them by hand then they're acting more like a burr than an end mill anyhow so there might not be a giant advantage to paying more for top notch cutters. Conversely, the luthier suppliers are charging PreciseBits prices for stock cutters worth 1/4 as much so if you're used to paying that much already then it'll be a shift in quality :)
Bob Garrish
PostPosted: Fri May 07, 2010 4:07 pm
+! for drillbitcity.
Good prices, and, I ordered Monday evening, and they were in my mailbox the next Wednesday noon (and, they are several states away) .
Phil
PostPosted: Fri May 07, 2010 11:36 pm
I've been getting bits from American Carbide lately
http://www.american-carbide.com/
