It is currently Fri Aug 15, 2025 1:18 am
PostPosted: Fri May 07, 2010 8:01 pm
Last Name: A
HI,
Robbie - this is a question for you - but I guess anyone can answer.
I tried the drill press method to cut out my headstock. It's great! Now I ran into one issue....and I think I know the answer but I wanted to ask. When I cut out my headstock, from the backside, once the drill bit hits the hardwood veneer, I got some tear out on my headstock veneer.... is there a way to avoid this ? Is it because my bit was not really that sharp ? what is the best way sharpen that bit - should it be sharp ? wouldn't it help to use a router bit in there ?
Thanks !!
PS - between your videos, and Chris Paulicks videos - and Cumpiano's book - I am building a classical ....
PostPosted: Fri May 07, 2010 8:13 pm
Are you using a beveled drill blank like Robbie does in his video. I sharpen it just like I do a chisel. Take your time when you first grind it. Keep it cool.
Mike Lindstrom
PostPosted: Fri May 07, 2010 8:29 pm
Last Name: A
I think that was my issue - it cut through the cedar ok - and the maple and black veneer - but when it hit the 1/16" walnut it took out small chunks from the sides. My headstock isn't the same shape as my template anymore - but that is ok - I will adapt. But I do want to avoid in the future - my bit was not "sharp" if you tried to cut your finger on it or shave hair it would take a great deal of effort.
PostPosted: Fri May 07, 2010 10:42 pm
Keep it sharp and it should work fine. Take small cuts with each pass.
