It is currently Sat Aug 16, 2025 8:18 pm
 Post subject: Pull frets or not ?
PostPosted: Sat May 15, 2010 11:33 am
I am curious if it is neccessary to pull the frets from the finger board , before heating to separate the fingerboard from the top for a neck removal? i am planning to use a clothes iron for the heat source, with protection for the top . thanks Jody
 Post subject: Re: Pull frets or not ?
PostPosted: Sat May 15, 2010 11:37 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Leave 'em in. The heat from the iron may loosen some of them. You can address this when you re assemble the guitar. A clothes iron will hang over the edges of the fingerboard. Take precaution to keep from damaging the finish on the top.
PostPosted: Sat May 15, 2010 1:41 pm
You can also damage the finish along the fretboard edge by using an iron (overhang). Depends on the finish type but usually the finish will bubble and you'll have to repair the finish on the neck.
PostPosted: Sat May 15, 2010 8:18 pm
Thanks I appreciate all the replies, Todd where do you find the 1/4" stock and how would you slot it ? thanks Jody
PostPosted: Sun May 16, 2010 10:52 am
First name: Tom
Last Name: West
State: Nova Scotia
Jody: Have had good success using a heat lamp. Find it gets an even heat to the wood and easy to control by varying distance. Use suitable insulation for areas you don't want to heat.
Tom
PostPosted: Sun May 16, 2010 3:49 pm
Thanks. I originally bought some heat lamps.. seems a bit primitive though.I am trying it on an old yamaha first then I need to pull the neck on my third build,, the learning process continues ! LOL thanks again everyone Jody
Users browsing this forum: Bing [Bot] and 12 guests
