It is currently Mon Aug 18, 2025 9:49 am
 Post subject: tips for jointing
PostPosted: Sat May 15, 2010 12:15 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Anyone have any? I am having a heck of a time and running out of wood!!!
 Post subject: Re: tips for jointing
PostPosted: Sat May 15, 2010 12:23 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
What tool(s) are you using?
What woods are you joining?
Mc
Mike Collins
PostPosted: Sat May 15, 2010 12:29 pm
There have been several posts in the past on jointing. Up to this point, I have been using my new world power jointer, but the traditionalists have been winning me over, albeit a little at a time. I just built the shooting board that Todd shows in the jigs section and used a Stanley No. 5 to join the last two that I did. I was surprised how quick I was able to get a good joint...quicker than walking down to the garage and using the power jointer.
I also used hot hide glue on those two tops...like I said, they are winning me over a little at a time. Since HHG worked so well for the top, I'll use it on the back and perhaps on the braces and bridge. However, I don't think that they are going to convince me that it smells good, as some have commented.
Alan
PostPosted: Sat May 15, 2010 12:33 pm
Buy a 24" fatmax extreme level with the machined edge and a 100 grit belt sander loop. Cut out a strip of the loop and glue to the machined edge with spray adhesive. Then run it back and forth on the plate edges on the shooting board just as if you were using a plane but make uniform strokes back and forth. I have found this the easiest way to get a gapless seam.
PostPosted: Sat May 15, 2010 12:41 pm
"Todd shows in the jigs section"
Where is the "jigs section"?
PostPosted: Sat May 15, 2010 12:47 pm
Here's what I do. It does take a bit of practice.
http://johnjayplatko.com/buildingasteelguitar5.aspx
PostPosted: Sat May 15, 2010 1:07 pm
Sorry...it's the "Fixture, Video, and Pictorial Tutorials" section.
Here it is:
viewtopic.php?f=10117&t=22540
PostPosted: Sat May 15, 2010 3:51 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I am using a stanley #3 plane and a shooting board. I have a power jointer but it is not giving results. I actually get a better seam doing it by hand. I ran a piece of oak through my drum sander to get a uniform edge and taped 80 grit paper to it. Still I can't seem to get a good seam.
I am trying to joint a set of IER, a set of black walnut and 2 sets of sitka spruce. Maybe the spray adhesive will do the trick.
PostPosted: Sat May 15, 2010 5:04 pm
First name: Joey
Last Name: Holliday
City: Palmetto
thanks for the videos they are very helpful. Apparently I need a bigger plane and a wedge built into my shooting board.
PostPosted: Sat May 15, 2010 5:24 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I use "The Easy Jointer" from Luthier Suppliers. Works like a dream.
Hutch
PostPosted: Sat May 15, 2010 5:46 pm
I used to struggle until I got my plane blade scary sharp see Todds youtube vids, and if the run out is very bad I've done the sandpaper trick and the last pass with the plane.
Formerly JJH
PostPosted: Sat May 15, 2010 6:40 pm
Last Name: Beebe
City: Zumbrota
State: MN
Zip/Postal Code: 55992
Todd Stock wrote:
Don't worry about the wedge, and a shorter plane will work...look at the way pressure is applied to the toe of the plane at the beginning of the stroke and shifted to the heel at the finish of the stroke. Also note the way to correct concave or convex surfaces.
A sharp plane is much more important than any other factor...if the blade is sharp, you'll get a decent joint with OK technique...if the plane is dull or poorly set up, you'll always have issues even with really good technique.
Excellent Advice Todd, also If you have a chance, check out David Charlesworth's video on handplaning it definatly changed my approch to using the handplane.
PostPosted: Sat May 15, 2010 7:23 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
There's certainly nothing wrong by doing it with a hand plane but a jointer that's properly set up will do
it just as well. If you're having problems, your infeed and outfeed tables are not parallel to each other. I suggest
you spend the time to get those right or having a jointer is useless.
And even if your fence is not set perfectly to 90 degrees, a jointer will still work: run one half with the A side toward the fence and the other half with the B side toward the fence.
PostPosted: Sat May 15, 2010 10:56 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Todd Stock wrote:
I respectfully disagree with the notion that a jointer will produce the same quality joint as a hand plane. For most purposes, a power jointed or sanded joint will work just fine, but there are those times that the extra strength and finer glue line is worth the effort. For woods like coco or for the thinnest glue lines in spruce, I want every possible advantage, and a hand planed joint is always going to be a little better than a power-jointed or sanded joint.
I don't disagree that a perfectly hand planed joint is superior to a jointed one. I just don't believe the difference is relevant
as long as the jointer blades are sharp, the machine is set up properly, and the work is pushed through slowly.
I can't tell a difference in the look comparing these joints side by side with a magnifier, and the strength of the glue line is, in both cases, stronger than the wood itself.
Sanding a joint, on the other hand, is inferior in my experience.
PostPosted: Sun May 16, 2010 3:38 am
How do you quantify this if the joint was taken theoretically up to 12,000 micro-mesh surely it'd be finer than anything a hand plane would achieve. Just playing devils advocate here.
Formerly JJH
