It is currently Sat Aug 16, 2025 2:04 pm
 Post subject: Pore filling tops?
PostPosted: Thu May 20, 2010 9:03 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
I'm some what of a newb, I've seen the zpoxy tutorials and was wondering about pore filling the top? Is anyone pore filling their tops? If not zpoxy how is the top addressed with respect to pore filling? Your input is greatly appreciated.
 Post subject: Re: Pore filling tops?
PostPosted: Thu May 20, 2010 9:11 am
If the top is spruce, there are no pores to fill. If you are using Koa, that's another matter entirely. In other words, the finish process depends on the characteristics of the wood being finished.
PostPosted: Fri May 21, 2010 8:37 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Thanks the top is redwood and really looks like it needs to be filled.
PostPosted: Fri May 21, 2010 9:44 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Just finished a classical with a sinker top....and it needed no fill ...and lacquered nice with a pre shellac coat.
KB
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Fri May 21, 2010 10:08 am
No need to pore fill softwoods as the generally don't have pores. Do not be tempted to put the z-poxy on your soundboard. You willl not get enough of it off when it comes time to glue on your bridge and the bridge will lift after a month or two.
PostPosted: Fri May 21, 2010 7:09 pm
First name: Greg
Last Name: Harrington
Agree that the bridge can lift. I have had two guitars (1 spruce & 1koa) and one uke(Koa) do this.
I do use epoxy on the sound board but now I put masking tape before the epxoy then remove it after finishing to glue the bridge.
Greg
