It is currently Sun Aug 17, 2025 6:34 pm
 Post subject: How dry is too dry"
PostPosted: Wed Jun 16, 2010 6:33 pm
Getting ready to buy a moisture meter but don't know what the moisture content should be. Help. Please and thank you.
RJS
 Post subject: Re: How dry is too dry"
PostPosted: Wed Jun 16, 2010 8:10 pm
Last Name: Abercrombie
Richard-
How are you planning to use your new wood moisture meter?
ie- for planks or for resawn wood for guitars?
PostPosted: Wed Jun 16, 2010 8:13 pm
For acoustic guitar. Resawn wood.
RJS
PostPosted: Wed Jun 16, 2010 9:42 pm
Actualy, both apply
RJS
PostPosted: Wed Jun 16, 2010 11:59 pm
Richard-
For guitar tops/backs/sides I think most folks just put them in a humidity-controlled room. It only takes a few weeks for the wood moisture to reach equilibrium with the room humidity. You can weigh the wood - when the weight stabilizes, you can assume that the wood is 'in balance' with the humidity in the room. I know that some of the older moisture testers wouldn't work accurately on thinner stock, but modern meters may be better in this regard.
There are tables which give the moisture content of wood in equilibrium with different relative humidity levels:
http://www.woodbin.com/ref/wood/emc.htm.
A moisture meter is useful for planks and thicker wood, especially if you are milling it yourself from logs, running your own kiln, etc.
PostPosted: Thu Jun 17, 2010 1:26 pm
Thanks John. VERY HELPFUL.
RJS
PostPosted: Thu Jun 17, 2010 10:49 pm
First name: duh
Last Name: Padma
How dry is too dry?
Well if you squeeze or rub the wood between your fingers and it turns to sawdust...its too dry.
blessings
duh Padma
