It is currently Sun Aug 17, 2025 11:56 am
 Post subject: All Cedar Guitar, part 2
PostPosted: Fri Jun 25, 2010 2:35 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Howdy,
Some of you might remember a couple months ago I asked about the feasibility of making an all cedar (western red cedar) guitar. After getting some input I decided to give it a try, knowing that the finished product would be somewhat fragile.
I just strung it up for the first time, and wanted to share some pics and my impressions.
This was a very "cheap" guitar. The "Frugal Luthier" strikes again. laughing6-hehe
Back and sides were cut from a 6X6X8 fence post I got at Menards. The post was quartersawn, and pretty clear. [:Y:]
Had to use multiple pieces to get the width I needed for the back.
The top is also multi-piece from a quartersawn 4x4 post, also from Menards. Very pretty, and some areas have 70 lines per inch.
The top bracing is a mixture of Douglas fir (also from Menards), WRC, and spruce. The X braces are the DF. It worked out fine, but it was not as easy to carve as spruce or cedar, so I don't think I'll be using it again, unless I can find some finer grained stuff....
The back braces are WRC, in a double X configuration.
Binding is ebony, bridge and fingerboard are Indian rosewood. Headstock veneer is black walnut.
Nut is corian, saddle is aluminum. :D
The head stock and heel block are made from some old mahogany I salvaged from the legs of an upright piano. The neck shaft was left over from another project.
I would guess I have about $75 in materials in this guitar, most of that being the tuners.
It sounds good. Probably my best so far. I shaped the braces based on how my previous one turned out (it was over-braced) and I think I hit the nail on the head with this one. I also made the soundhole bigger.
The action at the saddle is a little high yet.
Thanks for looking,
Phillip
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Jun 25, 2010 4:05 pm
Wow, that looks Marvelous! [:Y:] [clap] [clap]
PostPosted: Fri Jun 25, 2010 4:18 pm
First name: Hugh
City: Lake Oswego
State: oregon
That's good-lookin'! How was it bending the sides?
PostPosted: Fri Jun 25, 2010 7:42 pm
Awesome. I've been thinking of making a Menards budget special for the niece. I was thinking Mohog.
You'll have to give updates on how it holds up.
PostPosted: Fri Jun 25, 2010 7:56 pm
First name: Alexander
Last Name: T
Zip/Postal Code: 99025
OOooh a sleeper. Slick, simple and elegant. Way to be thrifty! So how long have you worked on this?
PostPosted: Fri Jun 25, 2010 9:38 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Nice guitar. Very clean work. Everytime I go to Menards, I look at all the maple and mahogany. I've found some curly stuff and pretty decent stuff for necks. I got a couple aspen boards last week that have some figure to them. I'm looking at making a hollowbody electric or something with that.
Jason Moe
LaCrosse WI 54601
PostPosted: Sat Jun 26, 2010 5:02 am
Congratulations Phillip that is a very impressive instrument. What type of finish did you use on it? I would love to hear what it sounds like?
Regards
Craig.
PostPosted: Sat Jun 26, 2010 11:45 am
First name: Phillip
Last Name: Patton
City: Yoder
Thanks for the kind words, fellas!
I was using a heating blanket and bending press, so it was a piece of cake. :D There was some springback, so I cooked them twice. The only real issue is that the inside of the waist crinkled some, which you can see in one of the pictures.
Hmm. I don't think my local Menards sells mahogany. I'll have to check that out for sure. Be great if they did.
I started it maybe 6 weeks ago.
Regards
Craig.
I used nitro lacquer over a base coat of shellac.
It sounds good to me, but I'm not a great player, so... I need to find a good player to record a sound sample.
Regards,
Phillip Patton
PostPosted: Mon Jun 28, 2010 12:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Geez, that looks really nice. It must be super light weight to hold.
How is the cedar back and sides after finishing? Any problem with dents and dings?
PostPosted: Tue Jun 29, 2010 1:57 pm
Ok, that's just cool.
Great idea, and congrats on your courage.
I love the look of those sides.
(Now next time, if you really want to save money, buy a chunk of PVC pipe, and cut your bindings out of that.
Just ask for the rosewood-colored PVC....)
PostPosted: Wed Jun 30, 2010 10:23 am
First name: Danny
Last Name: Vincent
That's pretty cool! I like the look of stripy Cedar. I guess you want to be sure not to wear your big ol' cowboy belt buckle when playing. :D
PostPosted: Sun Jul 04, 2010 8:59 am
First name: Phillip
Last Name: Patton
City: Yoder
Thanks!
Yes, it's by far the lightest guitar I've built so far, lighter even than my classicals.
There are a couple dents under the finish that I couldn't fix, and one or two since finishing. I guess that's life. I'll probably give this one away. Wouldn't feel right charging much for it.
Regards,
Phillip Patton
