It is currently Mon Aug 18, 2025 6:06 am
PostPosted: Sat Jun 19, 2010 12:32 pm
I am pretty confident in my fretting abilities but am just wondering before I start this refret if there is any good tutorials online. I know there is a great set of videos on youtube but I cant watch video right now.
And I may as well ask, do you find it essential to heat the frets before pulling?
PostPosted: Sat Jun 19, 2010 1:19 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Frets.com has some info and photos of fret jobs, and A google search will turn up more info than one can handle. I did my 1st refret on a vintage Gibson with the info from frets.com and had no problems.
Fred
Fred Tellier
PostPosted: Sat Jun 19, 2010 2:22 pm
First name: Corky
Last Name: Long
City: Mount Kisco
second vote for frets.com - Frank Ford's tutorial with pictures worked very well for me.
PostPosted: Sat Jun 19, 2010 7:40 pm
Last Name: Shanklin
City: Windsor
State: ON
I second Dan Erlewine' s Fretwork: Step by Step.
Bob
PostPosted: Sun Jun 20, 2010 6:42 am
Erlewine's Fretting DVD's the full set. Nothing better out there, forget the book unless you want it for ref. and get it as a package set from StewMac. It will be the best money you spent on fretting. He even has video of Frank Ford dressing the ends as well as others. Takes you from basic tools to advance work. He even slips a neck. I think there may even be a someone showing bar frets in there too. Nothing else out there compares and is on my must have or at see list along with Larry Robinsons Inlay tapes.
PostPosted: Sun Jun 20, 2010 6:50 am
Here's one that's quite good a luthier I know made I believe he lurks here occasionally too
Formerly JJH
PostPosted: Sun Jun 20, 2010 6:01 pm
I ALWAYS heat frets before removing them. Far less likely to pull chips out of the fretboard.
Old growth, shmold growth!
PostPosted: Sun Jun 20, 2010 6:20 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Exactly!!!!!!!, and don't just grab them and pull them out. Let the little pulling pliers work them out by kind squeezing under them.
PostPosted: Thu Jul 01, 2010 8:36 pm
First name: Keith
Last Name: Lally
City: Brookhaven
State: New York
What do you heat them with - a hair dryer?
Keith Lally
http://krl-guitar-building.blogspot.com/
PostPosted: Thu Jul 01, 2010 9:33 pm
First name: Fred
Last Name: Tellier
City: Windsor
A soldering iron with a flat tip, file a small slot in the face so it won't slip off the fret and burn the fingerboard. If you slide this back and forth across the fret a few times it will heat it enough to make the pull easy.
Fred
Fred Tellier
PostPosted: Fri Jul 02, 2010 10:01 pm
First name: Keith
Last Name: Lally
City: Brookhaven
State: New York
Heating them with a soldering iron worked great. Thanks for the good tip.
Keith Lally
PostPosted: Sat Jul 03, 2010 2:38 am
Why is a hot fret less likely to lift a chip?
PostPosted: Sat Jul 03, 2010 6:13 am
First name: Woodrow
Last Name: Brackett
City: Grover
I've always wondered that, but I've had better luck when heating them. It seems to me that heat should make the metal fret expand. This should make them harder to remove(???). Maybe heat helping is all in my head. I use a little white glue in the slot when installing frets. It's probably not necessary but it the way I was taught. I'm sure a little heat helps when removing them. I believe the most important thing for chip free fret removal is beveling the top of the slots, but we've got no control of that on a guitar that already has frets.
PostPosted: Sat Jul 03, 2010 11:43 am
Helping with glue is easy to see. But helping with the barbs pulling a chip up as they exit? Expansion from heat ought to make the fret fit tighter, not looser, and that would be regardless of whether wood or metal expands more.
