It is currently Sat Aug 02, 2025 10:01 am
PostPosted: Thu Nov 10, 2005 10:06 am
Does anyone have a source for replacement sandpaper for the radius dishes?
PostPosted: Thu Nov 10, 2005 10:10 am
Robbie, try John Hall!
PostPosted: Thu Nov 10, 2005 10:18 am
Robbie, John Hall gave me a source a few years back. These folks will put together whatever you need. I purchased 24" round with adhesive backs. I do believe they have a minimum order of 5 or 6. The supplier is Industrial Abrasives
PostPosted: Thu Nov 10, 2005 10:54 am
First name: Tom
Last Name: Dowey
City: Sudbury
State: Massachusetts
Zip/Postal Code: 01776
Robbie,
I have bought wide sanding belts. I bought them through woodworkingshop.com.
A 25 X 60 belt gives you 2 radius dishes worth.
PostPosted: Thu Nov 10, 2005 11:13 am
Mark Kett at guitar jigs. He has 50 grit paper that is
one piece which is a plus. The 50 grit lasts a very long time.
PostPosted: Thu Nov 10, 2005 12:15 pm
Harbor Freight sells a 5-pack of 6"x48" sanding belts for $12. I cut two of those into 4 pieces big enough to cover the dish (when I lay all four of them out), and I glue them on with 3M spray adhesive. Cheap and effective.Kelby38666.8448263889
PostPosted: Thu Nov 10, 2005 4:09 pm
   I have 24 inch disk with adhisive backed for $15. I have 80 and 100 grit. shipping is about $5
john hall
PostPosted: Fri Nov 11, 2005 1:30 am
I just got them from John. The quality is excellent and I highly recommend
them!
Sylvan
http://www.wellsguitars.com
PostPosted: Fri Nov 11, 2005 2:19 am
Thanks for the info!
PostPosted: Fri Nov 11, 2005 3:27 am
Thanks for the kind words Sylvan.
PostPosted: Sat Nov 12, 2005 11:13 am
John: Do you have 14" discs in 80-100 grit available?
tim...
PostPosted: Sun Nov 13, 2005 12:42 am
   I have 22 and 24 inch widths. I may be able to get the 14
john
PostPosted: Sun Nov 13, 2005 4:06 am
First name: Nelson
Last Name: Palen
I use a 24" flat disc for trueing the archtop ribs and had always used pie shaped segments in the past to make up the 24" dia. It was quite a process to cut and glue the pieces in place & removal was no fun either.
Bought a couple 24" discs from John a while back with self-adhesive.   Oh so nice!
Nelson
