It is currently Tue Aug 19, 2025 4:48 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Thu Sep 02, 2010 11:40 am
Well, after the re-topping and such, finally got some finish on #5. You've all seen it before, but it looks a bit better with a bit of a shine on it.
B&S - Cocobolo
2nd Top - Lutz Spruce (Shane) (well, so was the first one)
Binding - Australian Lacewood
Wide Purfling - Sycamore
Bridge - Cocobolo
Fingerboard - Ebony
Machines - Gotoh Premium with Non-binding rollers (very nice tuners)
Scale: 650 mm
A few more.
PostPosted: Thu Sep 02, 2010 11:49 am
It sounds good. Much like the others in timbre and voice. It has more bass, and a bit more growl in the open E and A strings, but does not seem to have lost anything in the trebles. Same overtones and sparkle. I'm hoping that the "growl" will settle down a bit after it breaks in a little. It did on #4. It's still pretty new. I have only played it a few hours.
Thanks for looking!
PostPosted: Thu Sep 02, 2010 12:16 pm
Country: Romania
Awesome colors! I wish I'd had the guts to try coco myself.
FP on the top truly looks great - quite impressive!
I don't approve the race strip - V joint combo but oh well, not sure I could convince you to change the neck after changing the top :D
What about using a pure concave shape for the heel profile as opposed to the slight S ?
Build log
Last edited by Alexandru Marian on Thu Sep 02, 2010 12:19 pm, edited 2 times in total.
PostPosted: Thu Sep 02, 2010 12:18 pm
Wow!
Super nice. Do you have previous woodworking skills?
PostPosted: Thu Sep 02, 2010 12:23 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Lookin' great, Waddy!
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Thu Sep 02, 2010 12:41 pm
That's one of the classicist headstocks I"ve seen for a long while. Very nice workmanship and color scheme. Clinton
PostPosted: Thu Sep 02, 2010 12:49 pm
Last Name: Hodge
An absolute beauty Waddy!!! [clap] [clap] [clap]
Bill Hodge
PostPosted: Thu Sep 02, 2010 12:54 pm
Oh, Alex, you're such a stick in the mud! Reach out, live a little. Think outside the box! :D
Thanks, though, I'm reasonably happy with the outcome. Part of the reason for the 5 piece neck, is trying to salvage a Sp Cedar neck billet that warped on me. I had to plane it down to flat and square then cut it up. So far, I'm only getting two necks out of it, and they are both 5 piecers. The new one will be a little more subtle. Single Rosewood strip with fine Maple on both sides, going into the V.
And thanks to the rest of you. I noticed a few have made comments since I started this answer.
PostPosted: Thu Sep 02, 2010 1:06 pm
Country: Romania
gaah What about covering the V with the backplate? pfft
Also, I might have told you before, this is your best rosette yet. Oh that neck [headinwall]
Build log
PostPosted: Thu Sep 02, 2010 1:08 pm
Marvelous! The top is mesmerizing and the craftsmanship is tops. That is a wonder FP finish and I wonder how much the cocobolo complicated keeping all of the light-colored wood clean.
PostPosted: Thu Sep 02, 2010 1:21 pm
Last Name: A
It looks great ! Your work sure is an inspiration for me and I am sure for others ! Did you shellac the inside a little bit ?
One critique though - it seems like the headstock slots are less perfect than the rest of the guitar - how are you cutting the slots ? It may be the picture angle also or just my eyes. Not sure if anyone else sees what I am seeing. The ramp on the treble side seems to reach a tab more to the nut, and the top of the slots seems they are a hair wider than the slot....
again the work is excellent - I am just trying to offer some critique -
how about a sound sample !
PostPosted: Thu Sep 02, 2010 1:30 pm
You are probably right, John. The whole headstock is done by hand. I do drill the slots with a Forstner bit, but then I finish them out by hand, with chisels, files, and sandpaper. I'm sure they aren't perfect. Good points, though. I should be more accurate on the headstock, particularly on the slots, since they are so visible.
Steve, I tried to be careful to seal the light wood with a Q-tip with shellac before I started any other finishing. I still had to scrape a few places after I started. I always see stuff that I should fix when I'm taking pictures, too, and there are a number of them.
I'll try to be more conservative, Alex! duh gaah
Thanks all.
PostPosted: Thu Sep 02, 2010 1:42 pm
Last Name: A
Waddy,
As you know i have two in production now and I know at least one of them needs extensive headstock/slots work - we'll see how those turn out.
PostPosted: Thu Sep 02, 2010 2:46 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Will done Waddy I like the Coco with the lacewood bindings. Your attention to detail is good, as for the headstock slots it is a hand made guitar and some variation is to be tolerated. I heard the the Cremona masters made every violin a little different as it was all hand saws scrapers and chisels, no maxi $ LMI and Stewmac jigs.
[:Y:] [:Y:] [:Y:]
Fred
Fred Tellier
PostPosted: Thu Sep 02, 2010 4:06 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Looks pretty good!
http://redrivercanoe.ca/
PostPosted: Thu Sep 02, 2010 5:12 pm
First name: Jim
Last Name: Kirby
Lookin' good!
Your rosettes have really come into their own. I've got to get around to that someday.
So, are you going to stick with the basic Romanillos design, or are you motivated yet to try something else?
Jim Kirby
kirby@udel.edu
PostPosted: Thu Sep 02, 2010 5:16 pm
First name: Jim
Last Name: Kirby
p.s. So, do you actually use that 20th fret?
Jim Kirby
kirby@udel.edu
PostPosted: Thu Sep 02, 2010 5:49 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
The coco and lacewood look great together, I am sure the color they will develop through the years will be stunning. T
PostPosted: Thu Sep 02, 2010 7:14 pm
Very Nice Waddy.
That's quite an unique head, I take it that's also another one of your signatures.
PostPosted: Thu Sep 02, 2010 7:15 pm
First name: Tim
Last Name: Warren
State: Ok
Zip/Postal Code: 73020
Wow Waddy, that headstock and neck is incredible.
Tim
PostPosted: Thu Sep 02, 2010 7:29 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
congrats, waddy!
beautiful, sweet instrument.
headstock is really, really nice.
very nice default ros.
yay!!!!! bliss
PostPosted: Thu Sep 02, 2010 7:45 pm
Jim: I only use the 20th for testing. The reason I put it is that a couple of players asked me if I ever thought of it. I hadn't , and thought I'd try it. I liked the look, and kept doing it. The guy who has my #3, uses it. There are a few pieces that call for it, but many players transpose it out. I wouldn't put it on a commission unless someone wanted it. And, yes, I think I'm going to keep building the Romanillos style. I like the small body, and the bracing, and it has a unique voice, that appeals to me. I will have to try some others though.
Chris: Yes, the headstock is also my design.
Thanks to all of you for your nice comments.
PostPosted: Thu Sep 02, 2010 8:32 pm
Last Name: A
Barrios !!
PostPosted: Thu Sep 02, 2010 9:13 pm
Waddy,
This is a beautiful guitar. I am very impressed. You have put together a very tasteful, and well built instrument. You are someone who inspires others to be great. Thanks for the pictures.
Mike R.
PostPosted: Thu Sep 02, 2010 11:42 pm
First name: Sen
Last Name: Goh
Country: Singapore
This is a great looking guitar! Waddy.
Congratz on successfully re-topping the #5.
The new tops looks really good under FP.
I like the rosette too.
Personanly I prefer if the heel cap is at the same level as the back; I think adding 1 or 2 more layers on the heel cap will bring it to be same level as the back.
But the heel cap sure matches the back very well though.
Sen CL Goh
http://senguitar.blogspot.com
cron
