It is currently Tue Aug 19, 2025 6:09 am
PostPosted: Sun Sep 05, 2010 9:17 pm
City: Tucson
State: AZ
For dots, marking is easy, make a ding right in the center and choose the appropriate bit to drill a correct size hole with which to place the dot, but how do I get a more extravagant inlay, like something one would find on a Gibson, to stay put in exactly the right spot while I trace around it to find out where to cut? Also, what should I use to trace around the inlay with?
Thank you all,
Ian
PostPosted: Mon Sep 06, 2010 12:28 am
Last Name: G
A nice brief description can be found on the fifth post at :
http://www.banjohangout.org/topic/182345
cheers
PostPosted: Mon Sep 06, 2010 2:54 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
I would add to the above, rub some chalk dust into the scribed lines prior to routing as this will enable you to see the the pattern much better.
Bill S.
Dream to be a luthier
PostPosted: Mon Sep 06, 2010 6:48 am
http://www.youtube.com/results?search_q ... inlay&aq=f
check out this series of videos and see if that helps.
