It is currently Mon Aug 18, 2025 10:56 pm
 Post subject: The Pineapple
PostPosted: Sun Sep 05, 2010 6:44 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I'm trying to come up with a pineapple theme tenor ukulele. I am not shaping the body like a pineapple. I will do a pineapple shape head stock. I was thinking I could route very shallow v groves in the top in a pineapple diamond pattern that I would fill with z-poxy, Then I started thinking that if I had to do any sanding I could have problems with this method. I thought of using a inlay of the same type of wood. I don't want it to be over powering.
Your thoughts.
http://goatrockukulele.com
 Post subject: Re: The Pineapple
PostPosted: Sun Sep 05, 2010 6:57 pm
Last Name: Killin
You could cut the sound hole like a pineapple. I'm thinking severl v shapes spaced to look like the body of the pineapple. Then a more solid area for the top.
PostPosted: Sun Sep 05, 2010 7:39 pm
To work properly, a ukulele soundboard has to be vey thin.
IMO inlaying it will weaken the soundboard and is a bad idea
PostPosted: Mon Sep 06, 2010 2:43 am
State: BC
Maybe some light/shallow laser engraving?
CVT Inc.
PostPosted: Wed Sep 08, 2010 7:47 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Ditto Jeff on the inlay idea. The rosette is scary enough
How about a wood burning iron? You could do that after the final sanding
Users browsing this forum: Dmaxwell, Terence Kennedy and 37 guests
