It is currently Tue Aug 19, 2025 4:46 am
PostPosted: Sun Sep 05, 2010 4:57 pm
Last Name: Sollod
This one was just strung up today. ...My first florentine cutaway. ...and this is the first time that I carved the neck. It took me a while to finish this one, but I'm pleased. This is number 5. I'm getting better with each build. I got kinda fansy this time. I hope I didn't over do it. I used a set of position markers I got from Andy Depaul that were called lotus. I thought they looked like agave cactus. So I got this idea of inlaying a southwest theme. I used 4 types of wood that I had in the shop... I also bound the headstock for the first time. I used a pretty wide abalone rosette and I was worried it would be too much. The tortoise purfling came out nice. That was the first time I tried that. By-the-way, I overdid the lemon oil and it looks a little greasy in the headstock photo...
www.swiftcreekguitars.com
PostPosted: Sun Sep 05, 2010 5:33 pm
Looks great Steve! Hope it sounds as good as it looks.
Chuck
PostPosted: Sun Sep 05, 2010 6:20 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Nice guitar, I usually don't like the plastic binding but that Tortoise looks real nice especially with the same in the purfling.
A lot of firsts on this guitar, you must be proud.
Fred
Fred Tellier
PostPosted: Sun Sep 05, 2010 7:07 pm
Last Name: Killin
I love the tortise purfling. Nice work. [clap]
PostPosted: Sun Sep 05, 2010 9:13 pm
City: Tucson
State: AZ
That's, magnificent.
 Post subject: `
PostPosted: Sun Sep 05, 2010 9:46 pm
That's a beauty!
PostPosted: Sun Sep 05, 2010 11:18 pm
First name: Ellison
City: Whitman
State: MA
Impressive! I love the headstock inlay. Keep up the good work!
PostPosted: Mon Sep 06, 2010 6:35 am
Very nice, Steve.
I particularly like the shape of your cutaway. And the walnut looks fine set off by the faux tortoise.
PostPosted: Mon Sep 06, 2010 10:45 am
Very Sweet! Congrats
PostPosted: Tue Sep 07, 2010 12:30 pm
First name: Randolph
Last Name: Morris
Beautiful!! Congratulations. Very clean and nice appointments. [clap] [clap]
PostPosted: Tue Sep 07, 2010 1:01 pm
Really nice - if it sounds as good as it looks you are on to a winner!
PostPosted: Tue Sep 07, 2010 2:02 pm
First name: Hugh
City: Lake Oswego
State: oregon
I second the comments on the purfling. How did you make it?
PostPosted: Wed Sep 08, 2010 8:25 am
Last Name: Sollod
Thanks for all the nice comments. These aren't the best pictures. If there is any interest, I can try some other shots. I'm quite pleased with the sound and set-up. I plays very well. You never really know how it will turn out until it's strung up, but it looks like I measured well. I checked the set-up dimentions against my Martin and Taylor and it is just right. It is bright sounding right now and I guess it needs time to open up. I've been trying to place an aquariam pump on it for a few hours at a time. I don't know... we'll see if that does anything...
The tortoise purfling was pretty easy to do. I cut (sliced) a piece of regular binding to the thickness I wanted using a jig like one I had seen here on the OLF. It consists of an several small blocks of wood arranged to hold the binding and a blade from an exacto set. The binding is drawn threw the jig by feeding it into the jig and then pulling the rest through. You pull it through several times, each time with the blade deeper (in the same position) until you go through. Then it's simply inlaid with B/W (or other purf of your choice) along with the binding. I'd show you a picture, but I'm at work and supposed to be working instead of thinking of guitar building. gaah pfft laughing6-hehe
PostPosted: Wed Sep 08, 2010 2:25 pm
First name: Hugh
City: Lake Oswego
State: oregon
You cut the binding to the width you want and then it will bend, is that it? Do you have to heat it?
PostPosted: Wed Sep 08, 2010 4:55 pm
Last Name: Sollod
No heating required because its plastic binding. A regular binding piece would not bend so easy, but if you cut it thinner it bends, no problem.
PostPosted: Wed Sep 08, 2010 5:37 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
I love the tortoiseshell binding too ... I've always been a sucker for it. You must be very pleased about that one Steve!
David Wren http://www.wrenguitarworks.com
Users browsing this forum: No registered users and 39 guests
