It is currently Tue Aug 19, 2025 8:16 am
PostPosted: Tue Sep 21, 2010 6:27 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I am currently debating on how to go about building this simple jig. However, I do not want to spend 89.00 on stew mac fiberglass go bars. I've seen Hesh's spring loaded go bars, but I can't find springs at a reasonable clip so far. Building this thing cheaply is my main concern. I have a lot of weddings to attend next month. Also how many bars do I need? Any suggestions would be greatly appreciated.
Joey
PostPosted: Tue Sep 21, 2010 6:37 am
1/4" Fiberglass Driveway reflectors at HomeDepot. Pull the reflector off and cut to length. I think they are about $1-$2 each. You can get a pack of the rubber end caps that fit on the metal closet organizers and they fit perfectly. They will keep the rod from slipping.
Dan
PostPosted: Tue Sep 21, 2010 7:13 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I bought 72" rods from Goodwindkites.com. What's up with the weddings? Are u being tapped fir gifts?
PostPosted: Tue Sep 21, 2010 7:43 am
+2 on goodwinds.
Here is my deck, please excuse the mess.
PostPosted: Tue Sep 21, 2010 8:15 am
First name: Nathan
Last Name: Swanger
City: Mechanicsburg
State: PA
Here is mine, just some threaded rod, ply as a stiffener with MDF layers, held together with some washers and nuts, i made it adjustable so that i could work on stuff at different heights. Also added some clear rubber hose as the threads will chew up wood pretty good, PVC could be used too. The go bars are from Bluescreek guitar, a sponser.
the whole setup maybe cost 40$ plus the cost of the gobars which John has for much cheaper than else where if you dont want to go the route of cutting up you own. (i like the rubber caps on mine)
PostPosted: Tue Sep 21, 2010 8:27 am
Built-in over the leg of an L-shaped bench, quartersawn ash bars.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Sep 21, 2010 8:45 am
First name: Martin
Last Name: Lane
City: Grand Rapids
I ripped spruce (SPF) into 1/4" x 3/4" bars. I go to benchtop-to-ceiling in my basement shop. there just happens to be an i-beam running 36" above my workbench, which was coincidental, but much appreciated. The whole setup set me back only a few dollars for the SPF.
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Tue Sep 21, 2010 9:03 am
First name: Martin
Last Name: Lane
City: Grand Rapids
Filippo Morelli wrote:
Martin, you sure that's not going to push your house up? wow7-eyes ... ;-)
Filippo
no more sagging floors, either. it's a win-win! [:Y:]
PostPosted: Tue Sep 21, 2010 9:10 am
Joey, I made mine recently (see viewtopic.php?f=10101&t=29126 ) for basically nothing..... just "tuned" (ie planed) some of the many feet of trim moulding I've accumulated over the years, and used the plywood protected ceiling as the top deck as others have done. The lower support is my vise-mounted plate carving jig, which is height adjustable.
Milton, ON
PostPosted: Tue Sep 21, 2010 9:18 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Mine is like Nates.
I love that thing!
A real time saver, and worth every penny.
Go bars from LMI,
can't remember how much.
PostPosted: Tue Sep 21, 2010 9:19 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I run mine off of the ceiling, too. Long go bars is not an issue for me, and not having the top of the go-bar deck in the way is a real treat. Remove the bars and away we go.
I'm building classical guitars, so they are built on a solera, which is not easy to stick into a regular go-bar deck.
Its funny, because when I started doing it this way everybody was using the regular deck, now I'm seeing many more people brace off of the ceiling.
http://redrivercanoe.ca/
PostPosted: Tue Sep 21, 2010 9:41 am
PostPosted: Tue Sep 21, 2010 10:31 am
Mine's on the ceiling. I use mostly various sized wooden dowels with rubber thread protectors. I also use the fiberglass driveway markers with the same thread protectors.
PostPosted: Tue Sep 21, 2010 11:13 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I too, found the 2' go bars a bother to use. It's nice to have the extra head room when cleaning up glue etc. I now have a storage shelf above one of the benches which is (really) well braced to the ceiling. Tonewood storage above & double 3/4" MDF shelf for the top deck.
I glued some canvas to the upper deck, after having a bar slip & scar a soundboard. The fabric effectively stops the bars from slipping.
I tried several kinds of wooded bars before I sprung for 1/4" fibreglass rods from "Into The Wind". Oak worked OK, Bigleaf maple relaxed after a very short time, so I tossed them. Alder did the same. Fir was the best I tried. Nice & springy & didn't take much of a "set" overnight.
I really like the extra head room, using 3 1/2 foot bars. I cut the bars to work with a large guitar body glue-up & simply shim up the dishes to the correct height when gluing braces or thin bodied instruments, like a Weissenborn.
I found the wooden bars worked fine & the cost was almost zero. The advantage with fibreglass is they are more tolerant of height differences.
Todd... What is a "corl pad"? I googled it with no results.
PostPosted: Tue Sep 21, 2010 11:24 am
First name: Marcus
Last Name: Bailie
City: Kirkland
I put mine where a vent would go in an old kitchen cabinet that was installed in my garage (where my shop is). Its just a slot system, so when i have to compensate for the width of a guitar, i just flip the sliding drawer over and i get an extra 3-4 inches.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Tue Sep 21, 2010 12:08 pm
First name: Peter
Last Name: Johnson
Country: Ceridigion, Wales
Which letter is next to L on the keyboard ? Lol
PostPosted: Tue Sep 21, 2010 12:11 pm
First name: Tim
Last Name: Allen
City: San Francisco
Mine is a plywood shelf mounted beneath the ceiling, similar to Daniel's. My go bars are cut from leftover 3/16" red oak strip flooring. The total cost was $0. I hoard scrap wood and was thrilled to have something to use it for.
Tim Allen
"Never hurry, never rest."
PostPosted: Tue Sep 21, 2010 12:57 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Ha I wish it was just gifts....travel, lodging, tux, food, bachelor party festivities and gifts.
PostPosted: Tue Sep 21, 2010 1:05 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Oh and thanks to everyone for all the suggestions.
PostPosted: Tue Sep 21, 2010 2:58 pm
Here's mine
I used to have a free standing one, and it was somewhat easier to use. The best thing about this one is that its out of the way, and the height (90 cm go bars). I think I will move it so I have access at least on 3 sides. Like Laurent, I prefer straight grained ash for the bars, but oak and birch is OK too. I bet hickory or perhaps osage would make great bars, at least they seem almost indestructible in archery bows. Most straight grained woods probably work, but you will have to adjust the dimesions according to its denisty to end up with equal pressure for the same length bars (as with bows).
PostPosted: Tue Sep 21, 2010 5:00 pm
i don't have any pics, but mine is suspended from the joists above my bench, and the bench is in a spot where i can get to it from both sides. makes it easier to clean up glue and a little easier to reach around and through all the sticks.
PostPosted: Tue Sep 21, 2010 7:05 pm
Here's mine. It's on a shop-made cart with a bunch of drawers (that I still need to finish). The whole thing is on casters so I can pull it out, rotate it and so on while I work then park it back in a corner out of the way. Started out with scrap wood bars but am now using 3/16" fiberglass rods from the kite store.
PostPosted: Tue Sep 21, 2010 9:10 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
If you have a harbor freight nearby they have a 3/16 fiberglass wire running kit that has 10 39 inch rods in it, part number 65326 that sells for around 14 bucks but is goes on sale for 7.99 or so all the time ,if you cut the rods to 2 foot lenghts and cut one with the female end and one with the male end then take two pieces and screw them together you can get about 20 pieces out of it..
MK5acoustics.com
PostPosted: Wed Sep 22, 2010 9:45 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
These are all surprisingly diverse....
Here is mine:
Users browsing this forum: Colin North, Ken Lewis and 35 guests
